It is currently Thu Apr 18, 2024 1:23 am
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Air Fuel Ratio at WOT
PostPosted: Sat May 02, 2015 9:35 pm
So refresh my old memory on what the ratio should be to safely run at peak hp?
Stoich is 14.7 and I am seeing max of 10.8 at WOT using the methanol......11.5 under heavy throttle.
What do you others run?
PostPosted: Sun May 03, 2015 7:26 am
Year and Trim: 1998 Buick Park Avenue
A bit richer is normal for WOT operation, particularly with modern adulterated gas. Running lean with methanol can wreck an engine in short order.
Roger.
PostPosted: Mon May 04, 2015 9:46 pm
Year and Trim: 2001 SSEi
1991 SE
I was running 11.1 at WOT, before my last tune. Now it's 12.0 or so.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
PostPosted: Mon May 04, 2015 10:48 pm
Thanks, I was hoping you would chime in....
I must be a little richer due to the addition of methanol in my 50/50 cooling water mix.
Under heavy throttle the A/F is 11.5 - 12.0 but as soon as the juice starts to spray at 8000 hz it drops.
Are those phenolic intercooler plates still available?
PostPosted: Tue May 05, 2015 1:28 am
Looks spot on to me with Meth
"Penelope" - 2003 SLE - 247k Miles
"Sydney" - 2000 Honda S2000 - 98k miles
PostPosted: Tue May 05, 2015 1:50 am
1991 SE
This is his new version http://www.ebay.com/itm/121396442528?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
PostPosted: Fri Jun 05, 2015 4:46 pm
Year and Trim: 2000 SSEI
looks about right to me.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Sun Jun 07, 2015 12:09 am
Year and Trim: 2001 Bonneville SSEI 32,000 miles bone stock
what are you running for a wideband?
PostPosted: Sun Jun 07, 2015 1:38 pm
Auto meter Pro comp
Users browsing this forum: No registered users and 4 guests
