Boost Gauge Tap on L36 http://www.pontiacbonnevilleclub.com/forum/forced-induction/topic43967.html |
Page 1 of 1 |
Author: | Backhoe [ Thu Aug 14, 2014 6:09 pm ] |
Post subject: | Re: Boost Gauge Tap on L36 |
Im not sure on your L36 vacuum config, but I tapped in to the vacuum line at the firewall side of the motor close to the MAP. |
Author: | Zeik75 [ Fri Aug 15, 2014 2:05 pm ] |
ChibiBlackSheep wrote: I must change my pants now.......excuse me. |
Author: | Jfridge92 [ Sun Aug 17, 2014 3:45 pm ] |
Holy crap they made a Paxton Novi kit for our cars??? Or did you fab that one up? Do you have a build thread? |
Author: | redzmonte [ Tue Sep 30, 2014 8:08 pm ] |
Jfridge92 wrote: Holy crap they made a Paxton Novi kit for our cars??? Or did you fab that one up? Do you have a build thread? That is a W-body. I think that was a ZZP kit IIRC. it could be adapted to fit a Gbody but not a direct bolt on. As for the vac source, you can tap into pretty much any vac source on the engine.. If you only have a "Boost" not a "Boost/Vac" then you can tap right into the boost pipe. FYI you can also use a Syclone/Typhoon/TGP AITS that threads into the boost pipe so that it doesnt pop out under boost. S |
