It is currently Tue Jun 02, 2020 3:58 pm
Post new topic Reply to topic  [ 12 posts ]
PostPosted: Sat Jan 21, 2012 9:48 pm
Year and Trim: 92 Buick Park Ave Ultra
86 Buick Regal T-Type
How much boost does a stock M62 Gen III make?
Is is ok to T off of the Charcoal canister line to measure?
Andrew
92 Park Ave Ultra, Gen III M62 Supercharger, Stock 3.5" Throttle body, Pulley and Boost Control from 95 Riviera. 3.5" Spectre intake piping, reduced to 3" stock air box with Spectre air filter.
All else Stock 92 Ultra
86 Buick Regal T-type.
TA-49, 206/206 cam, SMC Alchy injection, lots of other parts
PostPosted: Sat Jan 21, 2012 11:56 pm
Year and Trim: 1992 SSE
You can tap off any of the lines that come from the vacuum tree by the BCA.
WHITE WHINE - IT'S INTOXICATING. 1992 SSE Supercharged 236.26 ci (.040 Over)
15.090 at 90.2 MPH on old engine w/ slipping trans & melted O2 sensor - Gen 3 M62 and matching TB, Gen 2 Pully, Zillamotorsports Ported LIM, YT 1.72 Roller Rockers, SII FPR & Injectors, Easy Performance Gen 3 Air/Fuel Calibrator, Hypertech Thermomaster chip w/ 160 Thermo, TransGo Shift Kit, Infinity/Pioneer Speakers and 10" Subs, 1300 watts, 140 amp Alternator, Ricepipe CAI w/ heatshield, Pilot Angel Eye Foglights, Clear Corners, '02 17" Chrome Bent 5's, Magnaflow F-Body Muffler and Hi-flo Cat, McCoy Motorsports Ceramic Coated Ported Exhaust Manifolds, Fan Override, PowerSlot Slotted Rotors.
2009 G8 GT - Sport Red Metallic, loaded, SOLO Axlebacks, Rotofab Intake, Tuned, autodim Trailblazer mirror, removed intake manifold cover, HSV GTS triple gauge pod, two tone red-hot shifter and HSV SuperSport steering wheel, GXP rear sway bar and diffuser
PostPosted: Sun Jan 22, 2012 12:49 am
thats what i thought for the tap. i was seeing 2psi max at WOT. i thought that was really low. did come out of vacuum quick but i had expected around 7psi. i dont know what the M62 can put out. (vac was good at idle,18-20 in.hg)
PostPosted: Sun Jan 22, 2012 1:22 pm
There might be a leak in that line or the canister bleeds off positive pressure? Cap the line off to exclude the canister and try again. You should get about 7 psi. The gauge shows 0 when the engine's not running, right?
PostPosted: Sun Jan 22, 2012 1:40 pm
Moving to the proper section.
There are some possible questions related to the fact that this is a swap:
1. Is your evap system tied in to the vacuum manifold as it was stock? This would be 'post inlet', not pre-inlet? Any boost indication would only be seen at the vacuum manifold closest to the nosedrive.
2. Is your BCA and BCS properly controlled and connected both in terms of vacuum and in terms of the BCS solenoid (electrical)?
3. What are you using to measure the 2psi of boost? Be specific, links if possible.
Test your BCA mechanically using the red link in my signature.
PostPosted: Sun Jan 22, 2012 2:50 pm
instead T ing into the Fuel Pressure Regulator sense line as shown in the links, i T'd into the next one up on the vac tree which is the Evap charcoal canister.
Boost control actutator tested on the bench before install and after intall solenoid was tested as per links and all looks proper
all vac lines are stock configuration. im seeing good vac
good posibility about the evap canister bleeding boost. i will check without the canister connected.
Confirming that i should see about 7psi boost.
PostPosted: Sun Jan 22, 2012 2:54 pm
i also used a vac/ 30 psi mechanical pressure gauge. i then added another pressure gauge to confirm my first gauge was proper. pulled vac with hand held tester on test rig to confirm no leaks.
ill post again after running without the evap canister line.
PostPosted: Sun Jan 22, 2012 3:08 pm
If the BCA and BCS are working properly, and you don't have belt slip, it's physically impossible to have too little boost. It's not possible for a supercharger in our application to physically under-boost by itself. The only possibility is boost CONTROL. That comes down to the BCA function primarily. Boost indication may be another factor.
PostPosted: Sun Jan 22, 2012 3:30 pm
Good point about the BCS. Take the vacuum elbow off the bottom of the BCA and test your boost again. If it goes back up, check the wiring to the BCS. If the wiring is fine, replace the BCS.
PostPosted: Sun Jan 22, 2012 5:55 pm
looks like i had T'd into the line for the Trans modulator which also T's into the primary vacumuum block when i did my first test.
tested direct without the T and now showing 5psi and climbing to 6psi at the top of the RPMs.
ill also see if i get any more boost with the BCS bottom vac line off
thanks for the tips.
Andrew
PostPosted: Sun Jan 22, 2012 11:45 pm
You should get a few more psi than that. Stock gen 3 pulley, right? Any other mods? Roller rockers or anything else that helps move air in/out of the cylinders will lower the boost because there is less "boost stacking".
PostPosted: Mon Jan 23, 2012 11:01 am
Adding your swap and mods to your signature would help us a ton.
There are no new unread posts for this topic. If you want to make yourself laugh
olblueeyesbonne
28
3299
Mon Jan 05, 2009 12:29 am
tan96ssei View the latest post
There are no new unread posts for this topic. Make my supercharger scream?
ricosuave420
Wed Oct 30, 2013 5:15 pm
redzmonte View the latest post
There are no new unread posts for this topic. Too much boost?
BonnieBoy08
12
2061
Fri Jun 07, 2013 9:04 am
BonnieBoy08 View the latest post
There are no new unread posts for this topic. No boost
dave1003
Tue Apr 19, 2011 1:17 pm
myfirstbonnie View the latest post
There are no new unread posts for this topic. low boost
irish91983
12
2596
Wed Aug 08, 2012 1:33 pm
01bonneSC View the latest post
