It is currently Thu May 23, 2019 3:29 pm
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Aug 04, 2009 10:14 pm
Location: Cecil, PA - About 25 miles south of Pittsburgh
Year and Trim: 1988 Buick Lesabre T-type and 1997 Riviera
Hi all,
The bearings in my '95 Riviera's supercharger are going bad and I would like to replace the snout or rebuilt it eventually. However, I'm not sure I completely trust myself in doing the entire job. Anyone in the Pittsburgh, PA area willing to help me out sometime? Not anytime soon - I need to get the money for a rebuild kit or snout and the correct gaskets and things first.
I know it's a relatively easy job, but I'm just not sure I have the experience necessary to remove the entire supercharger and all such attachments and trust myself to get it back together...
-Andrew
1997 Buick Riviera - 102,000 miles : Series II L67/4T65E-HD : Intense intake : Ported S/C outlet : Ported LIM : Yella Terra 1.8 Ratio Rockers : LS7 Lifters : PLOG : Hogan Downpipe : INTENSE 3.5" MPS : 180 degree thermostat : AL104's : AC Delco 8mm wires : Shift Kit : STS strut tower brace : Custom Rear Strut Brace : F41 Sway Bars : Monroe HD rear air shocks : HD sway bar links : DHP Tune :
1988 Buick Lesabre T-type - 127,000 miles : Series I L67 : 4T60E-HD : AL 104's : 180 degree thermostat : '97+ Ignition Coils : Intense FWI : Walbro 255 : 2.5" Stainless Exhaust : Flowmaster 40 Series : STB : 'Caddy' braces : hood louvers: Karma Kustoms Ported M62 : Non-walled LIM : YT 1.8:1 rockers : LS7 Lifters : 2.4" S/C pulley : Custom PCV Oil bypass : B&M Trans Cooler : Sinister Tune
I also run the Buick Lesabre T-type Registry
PostPosted: Tue Aug 04, 2009 10:17 pm
What are your indications it is the bearings? Have you checked the coupler yet?
PostPosted: Tue Aug 04, 2009 10:53 pm
Well, while I don't ENTIRELY trust the dealer that told me it's the bearings (it's there for a few other problems too), they are good for almost everything else. They did tell me the pulley had no play, but I'm going to double check that when i get the car back. The car has 110,000 miles and I've heard of the bearings going bad at 50,000, though it's not common for it to happen at all. So until I get it back and check for myself, the problem could be either thing. It's also making a good amount of racket and I wouldn't expect a worn coupler would be QUITE that noisy, but I'm still new to superchargers.
PostPosted: Tue Aug 04, 2009 10:55 pm
Welcome to my still incomplete website:
http://www.3800supercharger.net/diagnosing.html
Let us know what you find, then we'll talk procedures.
PostPosted: Tue Aug 04, 2009 11:13 pm
Thanks willwren - I plan to get the car back this week so I'll be diagnosing as soon as I can. Site looks good so far!
Though regardless of what the problem is, bearings or coupler, I may just rebuild the snout while it's out anyway with new bearings and seals and whatnot. If I have to take the entire supercharger off to take the snout off anyway, I might as well go the extra mile.
PostPosted: Wed Aug 19, 2009 4:39 pm
Thought I'd update here since I just got the car back yesterday. Turns out the bearings are fine but my coupler has about 3/16" - 1/4" of play in it. It's baaaaaaaaaaad. I found a write up on how to remove the supercharger and change the coupler so I SHOULD be ok. But I'll post here if I have any questions. Thanks everyone!
-Andrew Z
There are no new unread posts for this topic. Supercharger snout leak?
Smithw500
Fri Apr 20, 2018 3:10 pm
redzmonte View the latest post
There are no new unread posts for this topic. GM sealer for supercharger snout
Ultra Boost
Fri Sep 05, 2008 1:34 pm
willwren View the latest post
There are no new unread posts for this topic. Snout Seal?
irish91983
Fri Feb 20, 2009 12:28 am
There are no new unread posts for this topic. Gen 3 Gen 5 M90 snout rebuild vids
Backhoe
Mon May 13, 2013 4:35 pm
Backhoe View the latest post
There are no new unread posts for this topic. Snout seal failure-->psi loss
6sic6
Fri Sep 26, 2008 1:43 pm
6sic6 View the latest post
