It is currently Fri Apr 25, 2025 6:35 pm
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Module Issues??
PostPosted: Thu Sep 17, 2020 1:33 pm
Year and Trim: 2002 se
Problem on 2002 se
Driver window problems going up and down (jerking)
Interior lights stay on
dash lights dim on their own
passenger window will only work sporadically
locks don't work
"bright light indicator staying on"
Is this a problem with the interior module? any help would be great.
Thanks
 Post subject: Re: Module Issues??
PostPosted: Sat Sep 19, 2020 9:54 am
be sure the little knob on left side of dash by fog lamps is not turned all the way clockwise - that turns on the interior lights.
bright light, you mean high beam - if you push the turn indicator stick forward, it will stay there and high beams stay on - check that
give the window a couple of light hits with your palm, does it move smoother for a bit?
https://my.gm.com/content/dam/gmownerce ... owners.pdf
see if there is a fuse for locks..........
can you move the mirrors with switch on pass door?
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
PostPosted: Tue Sep 22, 2020 4:11 pm
The dash light dim and brighten on their own. The "bright light" indicator stays on when I dim the headlights (sometimes). "door ajar" indicator comes on when all doors are shut.
I just think its some type of module going bad or a "junction box".
PostPosted: Thu Sep 24, 2020 9:16 am
Year and Trim: 2003 SSEi
The first thing I would do is check and clean all the electrical ground points. It's cheap and easy - well, cheap anyway. Poor electrical returns can exhibit some wacky symptoms. Do a site search, I think there's probably a post that points out the major chassis grounds.
gweg_b wrote:
People think I'm nuts, but Matt proved it.
Resident Tightwad
Screw you, Photobucket.
PostPosted: Thu Sep 22, 2022 9:47 am
I'm having the exact same issues. Has there ever been a solution discovered?
PostPosted: Thu Sep 22, 2022 3:07 pm
I'm confused. You are the original author from 2 years ago, but you never updated anything. Did the problems go away for a period of time?
PostPosted: Mon Sep 26, 2022 4:37 pm
those problems are still there. After doing alot of researching, I think of got a couple of things going on. On the windows, I think I need the driver door window "modulator". I'm not sure about the other stuff.
PostPosted: Wed May 01, 2024 9:18 am
Year and Trim: 2000 SE
Hazzard warning/turn signal flasher not working. Where can I find a replacement
PostPosted: Wed May 01, 2024 12:29 pm
I have them available. PM or email andrew.suderman@gmail.com
There are no new unread posts for this topic. Attachment(s) Common wire, ground, plug, or module - issues on 02 SE.
crash93ssei
15
7776
Thu May 01, 2014 11:36 pm
crash93ssei View the latest post
There are no new unread posts for this topic. Attachment(s) 03 SSEi drivers door electrical issues - all issues fixed
crash93ssei
27
7368
Sat Apr 12, 2014 3:22 pm
Oldman View the latest post
There are no new unread posts for this topic. Where is the BCM module located?
cosmic665
Sat May 07, 2011 11:16 am
dangrus4060 View the latest post
There are no new unread posts for this topic. Blower Module Connector
matt97ssei
Thu Aug 28, 2014 10:40 pm
gmman View the latest post
There are no new unread posts for this topic. DLC, PCM and Traction Contol Module???
skregal
Tue Nov 25, 2008 2:57 pm
BillBoost37 View the latest post
Users browsing this forum: No registered users and 4 guests
