Trac Light/E-Brake/Anti-Lock all on After Battery Replacemen http://www.pontiacbonnevilleclub.com/forum/everything-electrical-and-electronic/topic52269.html |
Page 1 of 1 |
Author: | MajorsSerj [ Sun May 05, 2019 6:25 pm ] |
Post subject: | Trac Light/E-Brake/Anti-Lock all on After Battery Replacemen |
Hello - Looking for help or trying to understand why on my instrument panel my antilock, Emergency Brake, And Trac off Lights on the instrument panel keep staying on after I recently replaced a dead battery.how can I fix this as when I jumped the car before replacing the battery it did not happen? Thanks for any and all help 2003 SLE^ |
Author: | 96 SSEi [ Sun May 05, 2019 8:59 pm ] |
Post subject: | Re: Trac Light/E-Brake/Anti-Lock all on After Battery Replac |
you may try removing the negative terminal from battery for 1 min and see if its normal when reconnected |
Author: | MajorsSerj [ Tue May 07, 2019 11:25 am ] |
96 SSEi wrote: you may try removing the negative terminal from battery for 1 min and see if its normal when reconnected Thank you for your response. But I’m just curious why would this cause any ideas? I will try tonight. |
Author: | 96 SSEi [ Tue May 07, 2019 12:02 pm ] |
sorry, no. But it happened to me on my 2000, but went away. since it started after a new battery, that would be a good starting point. I never use the acc. pos. terminal under hood - I go directly to the battery |
Author: | MajorsSerj [ Thu May 09, 2019 7:12 pm ] |
96 SSEi wrote: sorry, no. But it happened to me on my 2000, but went away. since it started after a new battery, that would be a good starting point. I never use the acc. pos. terminal under hood - I go directly to the battery So how long if you had to say, did it go away after you did that, by disconnecting/reconnecting the terminal? I did so today and still no change in this at all. DIC is now telling me OIL level is low, however I'm currently at 40% remaining according to DLC and I even confirmed underneath the hood that Im not low. I'm stumped on this and a bit frustrated, over something that happened after replacing a battery |
Author: | 96 SSEi [ Fri May 10, 2019 12:16 pm ] |
the 40 % is your oil life for change interval, so, you have 40 % of the time .remaining till next change . you can reset it after your next oil change. the oil level low is a sensor in the case - they are not related. I had a oil level low also, went away after oil change. the dash light show is only the security light now, but the trac/brake came and went for about 1.5 years - our cars have weird little electrical annoyances. do you get the 'service stability system' yet? did you use a proper good battery? |
Author: | Louiej99 [ Sat May 11, 2019 7:40 am ] |
I had my weird "no crank" issues that turned out to be the ignition switch. After I replaced it, the "no crank" issue went away, but a few days later the "anti-lock/trac off" issues started. It comes and goes. |
Author: | MajorsSerj [ Wed May 15, 2019 6:07 pm ] |
96 SSEi wrote: the 40 % is your oil life for change interval, so, you have 40 % of the time .remaining till next change . you can reset it after your next oil change. the oil level low is a sensor in the case - they are not related. I had a oil level low also, went away after oil change. the dash light show is only the security light now, but the trac/brake came and went for about 1.5 years - our cars have weird little electrical annoyances. do you get the 'service stability system' yet? did you use a proper good battery? 1.5 years, I would go insane. I hate those "dummy lights". I will disconnect it and let it sit for a few days as I have another Bonneville that is problem free right now I used an Interstate Battery, didn't go cheap or no name brands. |
