Tail Light http://www.pontiacbonnevilleclub.com/forum/everything-electrical-and-electronic/topic51632.html |
Page 1 of 1 |
Author: | deano55 [ Fri Mar 16, 2018 9:09 pm ] |
Post subject: | Tail Light |
My right rear tail lights are out on my 03 bonneville. The brake lights work, as does the turn signal, and back up light, first I thought it was the bulbs but it's not. With a test light there is no power coming to the connection of the running lights that's in the trunk. Is there a relay that is just for the tail lights? |
Author: | 96 SSEi [ Fri Mar 16, 2018 9:19 pm ] |
Post subject: | Re: Tail Light |
there is a fuse under back seat - brake lights |
Author: | deano55 [ Fri Mar 16, 2018 9:24 pm ] |
96 SSEi wrote: there is a fuse under back seat - brake lights my brake lights work though, just tail lights do not
Author: | 96 SSEi [ Fri Mar 16, 2018 11:47 pm ] |
ok, park lamp fuse - same place |
Author: | deano55 [ Sat Mar 17, 2018 9:23 am ] |
96 SSEi wrote: ok, park lamp fuse - same place ok, I'll check that out
Author: | deano55 [ Sat Mar 17, 2018 11:38 am ] |
deano55 wrote: 96 SSEi wrote: ok, park lamp fuse - same place ok, I'll check that out |
Author: | deano55 [ Sat Mar 17, 2018 1:09 pm ] |
Fixed, blown fuse must be due to the water, new bulbs and drilled holes to let the water drain |
