It is currently Sat Oct 24, 2020 10:57 pm
PostPosted: Mon Sep 29, 2008 8:15 pm
Arrived home to find a box on my doorstep from RadiatorExpress.com
Says to self: "Self, I still have about two hours of daylight left, I can change this right now..."
So, at 5:45pm I run the car up on the ramps and pop the box on the new radiator
Ok, pop the hood and speed-cool the radiator with a garden hose (don't feel like scalding myself tonight)
Grab an 8mm wrench and drop the battery cable, take a 10mm socket and remove the six bolts holding the radiator cover on and the fan. Pop the radiator cap, stick a bucket under the petcock and drain the old radiator out
6:20pm, take 1/2" flare nut wrench and undo the tranny cooler fittings. Channel lock pliers handle the hose clamps, ready to pull the radiator out.
6:45, old radiator is out, new radiator in place, fittings back on. 1 gallon of Distilled Water, and 3/4 gallon of glycol in. Reconnect the battery and crank the motor up and let it warm back up. No leaks, everything works. Hood closed and back off the ramps. Done! One hour radiator change. :wink:
Take this nasty P.O.S out to the curb for trash pickup tomorrow, take shower, grab a cup of coffee and regail y'all with this little tale :beerchug:
PostPosted: Mon Sep 29, 2008 8:17 pm
Year and Trim: 2002 Mazda Protege ES
*dang*, that old one is trashed :shock:
-Matt
PostPosted: Mon Sep 29, 2008 8:21 pm
Well, it is comming up on 20 years old. Stains are from the pin-hole leak in the core. It's been leaking for the past six months. I finally got tired of topping off the radiator.
FYI, my scrap yard will give me $25 per radiator...
-Andrew-
PostPosted: Tue Oct 07, 2008 2:04 am
Year and Trim: 1988 and 1987 Buick Lesabre T-Type
yea i was just about to say radiators get alot of money at scrapyards
~~~Freddy~~~ Wyotech Graduate, Future RCSAMS student
Pandora 1988 Lesabre T-Type 259000 miles
Darlington 1987 Lesabre T-Type 115000 miles
Cream Puff 1988 Lesabre T-Type 194500 miles
PostPosted: Sun Oct 26, 2008 5:46 pm
Year and Trim: 1999 SLE
That looks bad. Both of mine look better, although I did have to have a small pinhole fixed a couple of years ago on mine. Wife's hasnt been touched in the 10 years we have owned it, save for hose and coolant changes.
Glenn
1999 SLE 70k Stock for now
PostPosted: Sun Oct 26, 2008 8:24 pm
Year and Trim: ____
Awesome preventative maintenance. Hopefully that'll be some good reminders to people to change their aging radiator that could leave them stranded or cause severe damage from overheating. 100,000 miles or 10 years is probably the oldest any radiator should be trusted. That one looked similar to the one in my 89 when it was replaced at 120k at 16 years old. Half filled with scale.
John
This topic is locked, you cannot edit posts or make further replies. Not quite so Jiffy Radiator Replacement and Cooler Install
Alibi
Sat Feb 12, 2011 9:28 pm
Le91Bonnie View the latest post
There are no new unread posts for this topic. Jiffy Water Pump replacement....
clm2112
16
6541
Wed Jul 15, 2009 8:12 pm
chemicall View the latest post
There are no new unread posts for this topic. Radiator Fan not working
tom804
16
5005
Thu Nov 03, 2011 7:02 am
rustyroger View the latest post
There are no new unread posts for this topic. Radiator Fans Don't seem like they want to kick on
Alibi
Sun May 25, 2008 5:51 pm
Alibi View the latest post
There are no new unread posts for this topic. OIL PAN GASKET REPLACEMENT
pontiacsteve22
Fri Sep 26, 2014 12:11 am
pontiacsteve22 View the latest post
