Fuse box diagram http://www.pontiacbonnevilleclub.com/forum/1987/topic53106.html |
Page 1 of 1 |
Author: | squeakers220 [ Fri Dec 03, 2021 5:06 pm ] |
Post subject: | Fuse box diagram |
I need the diagram that tells you what fuses should be connected where for an 89 bonneville le 3500 I have no spark and want to check the fuses and relays my model has a box in the glovebox with relays and a fuse box under the steering wheel. Just need a visual so I know if I'm missing any fuses. my brother last worked on the car and pulled fuses so I suspect that's the source of my possible problem. if not I'm on to the icm, coil pack, and crank and cam sensors. I was driving her when I heard a loud bang. we discovered that the wires for the camshaft positioning sensor had been severed by the belt so fixed those also found that the fuse for the fuel pump had blew at the same time. replaced fuel pump as there was some resistance that caused it. I still have a cranking no start am at a loss as to what fuses are missing we tested the fuses in the car and they are all good but I feel I'm missing some. any help to get the evil back in the road she's my winter tank and I could use her my g6 is good but doesn't handle like the evil does in the snow. |
