Softer ride for bonneville? http://www.pontiacbonnevilleclub.com/forum/1987/topic51472.html |
Page 1 of 1 |
Author: | Karpov [ Wed Feb 07, 2018 1:57 pm ] |
Post subject: | Softer ride for bonneville? |
I had before 1990 lesabre and it was like flying carpet on speed bumbs etc. Very soft and smooth. Pontiac is stiffer, i think its mean to be like that. Now i have 1990 bonneville. Okay its simple: just switch buicks shock+springs. Only problem is high shipping costs. So which is better investment, springs or shock? Because i think that stiffer spring will limit smoothes harder than shock? |
Author: | 96 SSEi [ Wed Feb 07, 2018 3:31 pm ] |
Post subject: | Re: Softer ride for bonneville? |
YES, the springs will give you a softer ride - the shock will prevent the car from bouncing on the spring. you can look here if you are cheap like me....http://www.diseno-art.com/encyclopedia/ ... lamps.html if you use them correctly, they might work but, softer springs are your best bet. maybe you get lucky in scrap yard near you |
Author: | Karpov [ Wed Feb 07, 2018 5:37 pm ] |
Heh... Buick and Pontiac shared couple same shocks but not springs. Those cars are rare in here, so used parts are no go. |
Author: | MKMike [ Thu Feb 08, 2018 2:56 am ] |
Have you solved the starting issues? We haven't heard from you on that since you ordered the 195 thermostat... 1987/topic51373.html |
Author: | Karpov [ Thu Feb 08, 2018 4:30 am ] |
MKMike wrote: Have you solved the starting issues? We haven't heard from you on that since you ordered the 195 thermostat... 1987/topic51373.html Parts are here in this week. Because in europe its alleays 2weeks + if you dont pay big for faster shipping. |
Author: | Jrs3800 [ Wed Feb 14, 2018 11:31 am ] |
Some Bonnevilles had the F41 suspension( Firm Ride and Handling ) |
Author: | Karpov [ Fri Feb 16, 2018 3:06 pm ] |
Jrs3800 wrote: Some Bonnevilles had the F41 suspension( Firm Ride and Handling ) My bonneville is SE. I think SSEI is stiffest? When i ordered stabilizer bar bushings, i regonized that there was many different sizes of bushings, 28mm 30mm 31mm 32mm and 34mm. I had 32mm. I think that thicker stabilizer bar is stiffer ride? |
