It is currently Fri Jan 21, 2022 8:17 am
Post new topic Reply to topic  [ 4 posts ]
 Post subject: Transmission Bad?
PostPosted: Mon Feb 13, 2017 8:35 pm
Year and Trim: Pontiac Bonneville 89
I was about to take a trip last week.
I filled up on gas and hit the road. I noticed the car kinda jolting every time i slowed down and accelerated.
Then i made a right turn,slowed down at the light and it cut off.
Everytime i put it in Park it crank up,then when i went to Reverse or Drive.. It would shut off.
I finally held the gas.. Rev'd the Engine and pulled into a parking lot.
I let the car run for about 15 minutes and drove back home but the car wouldnt shift until i got past 40 MPH.
Went out of town for work.. Just got back today..
I tried to drive it and now it wont even switch gears.. Im guessing im doomed. #-o
Anybody had these problems.. Thanks for any feedback.
 Post subject: Re: Transmission Bad?
PostPosted: Mon Feb 13, 2017 10:24 pm
hi, did you make sure tranny fluid is clean, unburnt and to proper level? if it is low, check for leaks.
my 93 cutlass S had a bad tranny leak at 340,000 and would act similarly - kept it full and she lasted until I had to say bye 6 months later.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
PostPosted: Tue Feb 14, 2017 4:42 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 Camaro
'97 LeSabre
My experience with the 440-t4 - the 3rd sprag failed then locked up. That's what the jolting was while you were driving, the sprag not rolling smoothly because it's self-destructing, causing harsh/clunky/erratic shifting between 2-3. Then you finally got going fast enough to get into 4th gear that locks up the sprag. When you come to a stop, you're stuck in 4th and the engine can't idle. If you rev it in gear the sprag will pop, basically breaking completely, and you have 1st gear back, but should have lost 3rd gear as all the rollers would have fallen out at that point.
A telltale is metal glitter in the trans fluid, or metal chunks in the pan when you drop it for the fluid change.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
PostPosted: Tue Feb 14, 2017 9:19 pm
I added trans fluid and it is back to normal.. im taking it tomorrow to get it checked im sure it has a leak.. THANKS Fellas!!
There are no new unread posts for this topic. Transmission Applications
dandyd
Tue Feb 21, 2012 5:45 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Transmission Question
Z-type
Thu Mar 15, 2012 8:18 pm
MattStrike View the latest post
There are no new unread posts for this topic. transmission issues
bastard
Sat Jan 09, 2010 9:56 pm
There are no new unread posts for this topic. options for transmission removal.
rustyroger
Sun Mar 27, 2016 4:59 pm
rustyroger View the latest post
There are no new unread posts for this topic. 91 Bonneville Transmission Issues
Sat Jan 10, 2009 4:01 pm
