First off, you must abide by the rules set forth when using the gallery. You can view them here.
To access the gallery either use the link located at the top of any page, or use this link http://www.pontiacbonnevilleclub.com/gallery. (you must be logged in to access it)
(Click here to view larger versions of the below images)
Now follow these steps to create your own image album:
1) Click on the grey button labeled Create/order my albums.
2) Click on new.
3) Highlight new album in the box if it is not already
4) In the text box below, delete New album and enter whatever you want to call your album. Some examples may be your login ID, the nickname of your car, or something else completely.
5) Once you have made the changes above, hit apply modifications at the bottom of the screen. Hit ok on the popup verification window.
6) Hit continue on the next screen where it says creating album.
Follow these steps to upload pictures to you newly created album:
1) Click on upload file located on the right side of the red navigation bar.
2) Click thebrowse button by each line to locate the image on your local PC.
3) Once you have all your images selected, hit continue at the bottom of the page.
4) You will receive a successful upload screen, hit continue. If you do not see this screen, make sure that your images do not exceed 5000k (including any you have already uploaded). Also, smaller images (500K or less) work best.
5) On this screen you need to select the album you created from the list.
6) Now fill in ALL of the fields on the remaining portion of the page. If one of more fields (such as the year, trim etc.) don't apply to the image being uploaded, leave them blank then.
7) Hit continue once you are done entering the data. You will need to do this for each image you are uploading.
8) When all images have had the data filled in, you will get a confirmation page that it has been completed. Click Continue on the button.
Now at this point your image is out there for all to see. You can view it, and other images from you and others, by clicking on the user galleries link.
If you have any trouble with this, please post in the lounge asking for assistance.
