It is currently Sun Aug 18, 2019 10:18 pm
Post new topic Reply to topic  [ 7 posts ]
PostPosted: Tue Feb 12, 2019 3:29 pm
Year and Trim: 1994 Bonneville SE
1998 Bonneville. 219K miles.
Lately, transmission has been slow to engage first gear. Happens at initial start up and will continue after coming to a full stop, such as at a stop light. Problem goes away after about 5-10 minutes.
Fluid looks clean. No leaks, but topped it off with about 1.5 qts.
Could be the transmission control solenoid?
PostPosted: Wed Feb 13, 2019 11:41 am
If it was down 1.5quarts, it has a leak somewhere. Even being down that much on fluid, it can cause slipping issues. The shift solenoids control the shifts, not the clutches. I'd try some Lucas trans fix before anything else.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod | garage queen
2005 Town & Country Limited | Butane Blue Metallic | 290k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 210k | Official Bonneville Hauler
PostPosted: Tue Apr 23, 2019 1:07 pm
So I've changed the trans fluid and filter. Topped it off, and found no leaks.
Shift problem still exists: On initial startup when engine is cold, trans does not go into Reverse right away. Instead, I have to move the shift lever through all gears down to "1" and back up to reverse before it engages. Once the engine warms up, there is no issue. Shifting while driving is very smooth.
Any ideas what may be the problem?
PostPosted: Wed Apr 24, 2019 9:10 am
Worn clutches. Did you try some Lucas trans fix like I mentioned?
-Andrew-
PostPosted: Tue Apr 30, 2019 9:50 am
Well, hmm, I finally did add Lucas trans fix. And you know what? Transmission hasn't skipped a beat yet. Color me a Lucas fan from now on.
PostPosted: Wed May 01, 2019 9:05 am
It's the only mechanic in a bottle that works in my opinion. I hope it can be a long term solution for you!
-Andrew-
PostPosted: Wed May 01, 2019 9:21 am
Online
I've been putting in a little bit of Lucas every transmission fluid service and it's kept my car happy. It used to do this BS too.
"Penelope" - 2003 SLE - 193k Miles
"Sydney" - 2000 Honda S2000 - 67k miles
There are no new unread posts for this topic. Transmission does not engage
spoiledred94
21
3813
Fri May 29, 2009 1:49 am
spoiledred94 View the latest post
There are no new unread posts for this topic. Trans bucking from stop, cold start wont go into gear
Regulator
Sun Jun 21, 2015 6:17 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Transmission behaviors, hot vs cold
RJolly87
Wed Oct 15, 2014 10:01 pm
RJolly87 View the latest post
There are no new unread posts for this topic. Converter engage/disengage issues
Need For Steve
Thu Nov 18, 2010 8:35 pm
bad.moshi View the latest post
There are no new unread posts for this topic. breaks engage automatically and stick?
stone
Wed Mar 31, 2010 12:57 pm
willwren View the latest post
Users browsing this forum: No registered users and 13 guests
