It is currently Mon Feb 18, 2019 2:36 pm
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Broken rear wheel stud
PostPosted: Sun Feb 04, 2018 11:05 pm
Year and Trim: 96 Bonneville SSEi
I searched around and found info on replacing front wheel studs but nothing specific to doing the rears.
On my beater Bonny, someone had already replaced all 5 studs on the passenger side, but the driver side rear had 2 that were cross threaded. In the process of changing wheels today, I broke one of the studs and the other cross threaded one is so toast that you cannot thread a nut back on it.
I may as well mention I need to install new brake shoes, so i would like to do the repairs all at once. Is it more of a process to replace the rear studs?
This is a $600 beater car with lots of miles and I want to keep repair costs to a minimum, and Mickey Mouse repairs are ok too....like cutting a hole behind the glove box so I can use a screw driver to move the blend door actuator so I don't have to pull the dash to replace it lol.
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
PostPosted: Sun Feb 04, 2018 11:30 pm
1994 Buick Regal Custom
I think the studs hammer out once you have the brakes tore down.
Of course, the process may anger the wheel hub, which may need to be replaced anyway if the studs don't want to come loose.
Replacement hub units would be a quick and easy route, keeping labor to a minimum however, and they come with studs anyway.
Just keep in mind what's at stake if something goes wrong in this area, even if it is 'just a beater'.
And then I just realized you are in Canadia, which means rust.... that will probably not be fun no matter which way you slice it.
~Randall~
PostPosted: Mon Feb 05, 2018 1:25 am
the backing plate will have to come off maybe. you will know for sure when you remove the drum
to protect the bearing, put wood between the hub and knuckle to support around the stud while you hit.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
PostPosted: Mon Feb 05, 2018 8:49 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
It's easier to replace the rear studs.
You don't have to remove the backing plate.
Once the brake shoes are off it's a simple matter of hammering out the old stud and pressing in the new.
At work we use 3 thick washers and a spare lug nut with the wider (non-tapered) side against the washers.
Pulls the stud into place in a jiffy.
PostPosted: Mon Feb 05, 2018 4:27 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 Camaro
'97 LeSabre
The only thing you may have trouble with is finding a stud with the same size knurl. So you'll have to bring the broken piece in with you to a parts store. The problem I've been running into is that the aftermarket replacements seem to have two different stud hole sizes, and they are both different than OE, and the auto parts stores seem to have a mish-mash of replacement studs. The knurl count doesn't really matter as long as the diameter is right, you might need a caliper to check.
Blow all the things! Wait, I meant boost. Boost!
Runs:
'93 Pontiac Bonneville SSEi - Twincharged, manual, and lots more! Build thread
'97 Chevy Camaro - 3800 supercharged, T5, T-tops
'05 Cadillac STS - V8, AWD, her DD
'92 Olds Trofeo - Fair weather DD
'84 GMC Sierra Classic - Twin turbo 3800
'97 Buick LeSabre - L67 winter DD
'92 Pontiac Bonneville SSE future project
Doesn't run:
'87 Buick LeSabre T-type - future victim
'67 Buick LeSabre - future victim
PostPosted: Mon Feb 05, 2018 5:45 pm
Thanks for all your great answers. Matt, that's interesting to know, as when I bought the car, all 5 studs were replaced on the passenger side and that wheel now uses different lug nuts.
Over the nexy few days when I have a chance, I'll have to tear it down and see what it looks like. I'm just asking questions before I dive in to know what to expect.
Also, southern Alberta isn't bad for rust. We don't salt here, so both my cars are pretty clean, compared to the Ontario junk boxes I used to own and work on.
Thanks again!
PostPosted: Mon Feb 05, 2018 6:45 pm
Just watched a video on replacing the rear hub. Super simple on these cars. Local wrecker has a used gun for $60 so I’m just going to slap that on and a new set of shoes and we’re back in business.
Eats into the race car fund for next week, but can’t have a race car without a daily beater lol
There are no new unread posts for this topic. Another first..first broken wheel stud
lunchboxx
27
2272
Sat Jan 24, 2009 3:25 pm
lunchboxx View the latest post
There are no new unread posts for this topic. Replace front wheel stud? DONE!
Bob Dillon
Sat Sep 28, 2013 6:41 pm
Bob Dillon View the latest post
There are no new unread posts for this topic. Broken rear ball joint
ChilinMichael
Tue Nov 08, 2011 2:43 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. rear wheel bearing.
hall1971na
Mon Nov 28, 2011 10:31 am
hall1971na View the latest post
There are no new unread posts for this topic. Rear wheel cylinders
J Wikoff
Thu May 20, 2010 9:53 am
J Wikoff View the latest post
Users browsing this forum: No registered users and 14 guests
