It is currently Mon Jan 21, 2019 2:10 pm
Post new topic Reply to topic  [ 2 posts ]
 Post subject: 1997 Front trans mount
PostPosted: Tue Mar 13, 2018 1:38 am
Year and Trim: 2000 Pontiac Bonneville SE
My 97 Olds 88 keeps wearing out the left front trans mount. Has anyone figured out a solution to this?
1997 Oldsmobile Eighty Eight LS
1993 Buick Regal GS Coupe
1992 Buick Regal Limited Coupe
PostPosted: Wed Mar 21, 2018 10:39 am
Year and Trim: '93 SSEi
'05 STS-4
'97 Camaro
'97 LeSabre
Use a bolt and sway bar bushings to limit how far it can move. Rubber doesn't do well under tension. If you have access to a welder, you can modify the mount so that it has two bolts with bushings. The idea is that they are just tight enough to not rattle, but loose enough that the stock mount still absorbs the majority of the vibrations when not under tension like it is at WOT.
Blow all the things! Wait, I meant boost. Boost!
Runs:
'93 Pontiac Bonneville SSEi - Twincharged, manual, and lots more! Build thread
'97 Chevy Camaro - 3800 supercharged, T5, T-tops
'05 Cadillac STS - V8, AWD, her DD
'92 Olds Trofeo - Fair weather DD
'84 GMC Sierra Classic - Twin turbo 3800
'97 Buick LeSabre - L67 winter DD
'92 Pontiac Bonneville SSE future project
Doesn't run:
'87 Buick LeSabre T-type - future victim
'67 Buick LeSabre - future victim
There are no new unread posts for this topic. Does this look like a failing front trans mount?
irkwerks2
Tue Oct 21, 2008 3:41 pm
agrazela View the latest post
There are no new unread posts for this topic. rear trans mount
1337ssei
Sun Mar 15, 2009 4:08 pm
sandrock View the latest post
There are no new unread posts for this topic. rear trans mount question
trf_ssei
Thu Aug 20, 2009 10:15 pm
trf_ssei View the latest post
There are no new unread posts for this topic. Motor / trans mount is confusing me
skregal
Sun Apr 03, 2011 12:15 pm
skregal View the latest post
There are no new unread posts for this topic. 1997 SE Pont.Trans. Issue
97SEBonnevilleMan
Wed Jun 11, 2014 12:23 pm
97SEBonnevilleMan View the latest post
Users browsing this forum: No registered users and 10 guests
