I followed the buttermore/slug cable instructions to the T. I bought this scanner on e-bay, and it works, but it keeps saying connection problem. Any ideas? It's on a 94 SSEi. Seems like this scan tool DOESN'T work with more 94/95 cars and it DOES work with :?. In the case of no ideas, anyone have any interest in buying this from me for what I paid ($35 dollars shipped)? If you want the extra homemade 9115 cable, I'll give it to you for an extra ten bux.
I didn't use solder - as I didn't want to butcher the OBD cable if it didn't work. Think I'm going to HAVE to solder it and maybe get thicker wire for it to work properly? I didn't think it'd seem much current, therefore didn't see a reason to use thick wire. I even burnt the tips of the wires to get any protective coating off.
- Josh
1994 Bonneville SSEi - 136k mi - FWI, 180* T-stat, Fresh upper gaskets
1997 Bonneville SE - 110k mi - H4U, 3.06:1, Tinted Tails, Bridgestone Potenza G009 225/60/16s
Performance: INTENSE PCM, INTENSE 180* T-stat, Gutted air box, K&N air filter, Ported LIM, Borg Warner Wires, NGK TR-55 Plugs, Adjustable Trans Modulator.
Bells and Whistles: Flowmaster 80 crossflow muffler w/ quad tips, 2x Kicker CVR12 Subs in vented box, 1000W RMS 1-ohm American Bass Amp, Alpine MRP-F200 4-channel amp (temporary), Infinity 60.7CS 6.5" Component System (front), Blaupunkt 3-way 6x9s (rear), Pioneer DEH-P6900UB Head Unit, Hardwired Whistler Pro 58 Radar Detector, Hardwired Navigon 2100 GPS
Do you have an ohm meter? Or a continuity tester? I am wondering if you checked the pinouts to make sure the colors have not changed in the production of the newest batch of cables. The colors I found in my cable several years ago may no longer match what you are using. If you used only the color codes as a guide, that could be why it is not working for you. Also, you might want to check your splices to make sure that combustion residues and other oxides might have resulted in a poor or intermittent connection. You could just use small wire nuts or solder-less butt connectors to join the wires in a more secure manner. If you have not already done so, you may want to check the ends of the spliced cable to make sure the pins are connected as shown in the diagram.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
As Mr. Buttermore suggested, it was the wire colors. It's working perfectly now. Thanks! :D
Here's my hard copy of the wire color conversions:
obd
pcm - bare
ground - gray
12y - white
ser data - green
serial
red - 7
bare - 3
white - 15
gray - 14
blue - 11
green - 10
OBD II Plug -> Serial
Bare -> Red
Gray -> Gray
Green -> Blue & Green
White -> White
Some time here I will write up a diagram like like bill's.
I didn't get much chance to play with it as all the fuel has basically leaked out, but is it normal to be showing 100% boost at idle, and TPS reading 17? lol.
- Josh
putertopia wrote:As Mr. Buttermore suggested, it was the wire colors. It's working perfectly now. Thanks! :D
obd
pcm - bare
ground - gray
12y - white
ser data - green
serial
red - 7
bare - 3
white - 15
gray - 14
blue - 11
green - 10
Bare -> Red
Gray -> Gray
White -> White
hey im trying to fix my wire but i am having a some trouble..
first question is.
how do i tell where the wires go on he obd clip. i can figure out the serial as its number. but need help with the obd clip. cant figure out where to correctly put the wires..
second question is what do i do with all the other wire thats there.. theres about 16 wires in my harness but fixing the harness only mentiones useing about 6 0r 7only.?
i already have my harness open and apart if pics are needed to see where the wires were normally connected to..
