HELP!!! Transmission in a 95 http://www.pontiacbonnevilleclub.com/forum/1992/topic51214.html |
Page 1 of 1 |
Author: | laskowskifamily [ Fri Dec 01, 2017 2:50 pm ] |
Post subject: | HELP!!! Transmission in a 95 |
HELP!!!! I am gonna cry!!! we bought a 95 Bonneville & the transmission went in it within a month! never even put the plates on it!! So we bought a damaged 94 Bonneville, that we took the transmission out of & its at the shop right now... we just noticed that the key tag says 92 and double checked the door, yep it's a 92!! I'm afraid this guy totally screwed us!! Can anyone tell me if a 92 is compatible with a 95??? thanks |
Author: | J Wikoff [ Fri Dec 01, 2017 3:44 pm ] |
Post subject: | Re: HELP!!! Transmission in a 95 |
Supercharged or naturally aspirated? |
Author: | 96 SSEi [ Sat Dec 02, 2017 1:14 am ] |
yes, I believe it will be if the trim matches, the supercharged engines need a different one than the lower models. the tranny place would have told you already if it wont work. |
Author: | redfury [ Sat Dec 02, 2017 10:22 pm ] |
...might be tricky, the 95 model year was a one year only for a lot of things with OBD1.5 in the mix. I know that you have to put a 95 transmission in a 95 Chevy Astro. |
Author: | MattStrike [ Mon Dec 04, 2017 12:15 pm ] |
http://www.gmtuners.com/tech/440_4T60E_4T65E.htm I don't believe you can just drop a '92 trans into a '95. It will mount in and bolt down fine, but there were slight differences in the controls internally. I think the main difference would be the torque converter apply strategy (extra solenoid on the 95) which is not compatible. I don't know if the harness is different. It might bolt in and plug in fine, but you would have issues and a check engine light for the TCC, and reduced gas mileage. |
Author: | Jrs3800 [ Sat Dec 09, 2017 12:59 pm ] |
Both the 92 and 95 Bonneville 4T60E use the PWM strategy... But they are wired differently internally... I really wouldn't go backwards from 94- 95 to 92, but I would go forward like 96 and or 97 as the 4T60E was improved for those years.. the 94-97 4T60E for the H body is wired the same.. 92-93 is wired differently.. |
