It is currently Mon Jan 21, 2019 10:12 am
Post new topic Reply to topic  [ 9 posts ]
PostPosted: Thu Feb 02, 2012 4:10 pm
Year and Trim: 1993 Bonneville SE
Either I'm missing a step involving compressing the sway bar to the control arms in order to add its last nut or the set that I bought doesn't fit.
Here's a few pictures of what I got.
I have a couple of options here. There is simply no threading poking through allowing me to tighten on the nut.
I can:
A) Get a new set (though I don't see this being different)
B) Shorten the sleeve (part 1)
C) Shave a few of the bushings (part 2)
D) Find a longer bolt somewhere (part 3)
Any suggestions?
Bonneville SE -- Cruising the mountains, surfing the lowlands, and passing broken down competition since 1993!
PostPosted: Thu Feb 02, 2012 4:13 pm
Shorten the sleeve.
PostPosted: Thu Feb 02, 2012 4:28 pm
Is this normal? Anybody else have this happen? I wish I had a belt sander!
PostPosted: Thu Feb 02, 2012 5:22 pm
Yeah, IIRC it's in wren's write-up for installing them. I'd remove a little at a time with some sort of grinder, trying to make sure you keep it somewhat flat...
PostPosted: Thu Feb 02, 2012 6:03 pm
Hmm, I even had his writeup sitting next to me printed out and somehow missed that. Thanks!
PostPosted: Thu Feb 02, 2012 8:30 pm
Well in case anyone also has this problem, I just applied a little pressure to the center of the sway bar with a jack so that it would compress the ends enough to get the top nut threaded. Thanks for the writeup and help guys!
PostPosted: Fri Feb 03, 2012 1:19 pm
Year and Trim: 2008 Aura XE
You need to put some pressure on the control arm using a jack, because when you jack up the car the control arm falls which makes the distance to far for the bolt
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
PostPosted: Fri Feb 03, 2012 2:15 pm
Just get both front wheels off the ground, then you don't have the sway working against you.
98 Infiniti vq35'd i30: 13.3@104mph, 30MPG Hwy
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Fri Feb 03, 2012 11:56 pm
I was under the impression that you should keep the car on rapids with weight on the wheels....?
Oh well, it's done now and drives like it's young again!
There are no new unread posts for this topic. Steering clunk (Pictures posted of swaybar endlinks 5-20-11)
LeSabre in Buffalo
Wed May 25, 2011 8:56 am
LeSabre in Buffalo View the latest post
There are no new unread posts for this topic. Zerk fitting won't take grease
imidazol97
Wed Jun 22, 2011 3:43 pm
John Deere Boy View the latest post
There are no new unread posts for this topic. Rubber vacuum fitting replacement?
ron350
Thu Feb 12, 2015 5:38 pm
bonniebird View the latest post
There are no new unread posts for this topic. Heater Hose Fitting O-ring - Stumped!
96LSS
Wed Feb 02, 2011 10:51 pm
There are no new unread posts for this topic. Heater hose inlet fitting nylon insert?
beater98se
Sun Oct 25, 2015 11:54 pm
MattStrike View the latest post
Users browsing this forum: No registered users and 6 guests
