NOTE: This is not just a poll; I would really appreciate comments/advice as wellHi, I've been a lurker around here for awhile learning quite a bit about vehicles and maintenance in general (with scotty killmer/chris fix as well). This is a rather large post, I tried to give as much detail as possible and format it for easier reading. please feel free to skip to pictures/parts&problems or look at the scan data; all advice/input is greatly appreciated.
I am posting here to find a general consensus on weather or not it would be worth putting the $300-$400 to fix my
1996 Pontiac Bonneville SE N/A (not supercharged 158k miles) or if I should cut my loses and buy a new(used) vehicle.
The value of the vehicle is 700-1200 at most; however, if fixing the issues can push another year or two out of the vehicle I think it would be worth it. Not only will I learn a thing or two (first time doing this type of work on my car myself) but I really enjoy the ride and vehicle; not to mention finding another vehicle this size is quite difficult.
The problems I am having include
loss of power/acceleration,
UIM/LIM failure, valve covers leaking, transmission fluid leaking (and thus slipping) and
possibly pcm/alternator issues (some codes below, all one time and never reappeared after clear;I also changed wires/plugs 2 weeks ago)
P1406 EGR valvue pintle pos cir malf
P0300 random misfire
P1106 MAP sensor Cir intermittent High voltage
P0133 Heated oxy sensor b1s1 slow response
P0706 Transaxle range switch performance
Below are pictures and descriptions of my problems:
Quote:
Parts~~~~~~~~~~
I've gathered the following parts to fix the issues and if anyone would recommend additional fixes or different parts (something missing) let me know please.
this(atp intake) is $15 shipping, is the Dorman one worth less money with free shipping?
ATP 106001 UIM kit with (amazon)felpro ms 98014 T Aluminum LIM gaskets (amazon)Dorman metal elbows (amazon)fel-pro vs50080R]Valve cover Gaskets and fel=pro es72833 grommets? (for valve covers....amazon)pep-boys $9 fel-pro transmission gasket
oreily $14 durlast filter trans gasket combo (just for filter)
major parts total ~$186~~~~~~~~~~~~
optional parts~~~~~~~~~~
eventually id like to also replace a few other items as well
~~radiator amazon~~ac-delco blower motor (need cooling tube too $10; probablly why it failed in 3 years when the dealership put a new one in)
~~adjustable transmission vacum modulator
~~new ideal bearing for AC compressor pulley
~~ find why/where I have a dash light short (fuse blows constantly)
~~find out where/why my under carpet padding gets wet during/after storms (very humid car and smell...rare in AZ)
full parts total $400~~~~~~~~~~~~
end of parts~~~~~~~~~~
Pictures~~~~~~~~~~
I noticed my coolant was quite low when I changed some spark plugs and wires a couple weeks ago and topped it off (about 6 qrts; have not checked it in 2-3 years and its had the green liquid since I bought it). since then I've lost 2 Coolant tanks and noticed allot of calcified green tint (burnt coolant?) and coolant around the fuel injectors and side of engine/transmission (failed UIM/LIM). looks like it was made in 05/2006
(below) transmission gasket failed on one side; it is really dirty under here so i needed to use UV Dye to find it.
some black/brown gritty sludge stuff in overflow tank (I saw some black floating oily looking stuff in the transmission too; it was a very small amount but it looks like a tiny amount of a black oily substance(looks like a patch of floating oil in radiator neck) is getting into the radiator.(no pics)
possibly some small radiator leaks on each side (hard to see driver side leak) so not all the coolant may be leaking around/in the manifolds (other coolant leak pics below)
engine pics; also crank case and dip stick dont show milky signs of coolant being mixed in with them (dipstick looks like clean oil) but it glows under UV light (detergents in the oil may also glow under uv light so im not so worried)
here is a link to an album with other pics of the engine, Bonneville, and repair reports from BlueDriver (some rust and massive clear coat failure....hot sun in AZ is more damaging than I expected) =/
Car troubles shared album (google+) ~~~~~~~~~~
Scan Data~~~~~~~~~~
I also have some scanner data (lemur BlueDriver) if anyone wants to take a look at it; included is some mode 6 data error codes/reports and some live drving data (some idealing some driving around also had some random stalls in 1 or 2 logs.
google drive spreadsheet several dates (lots of trips) (I have no idea how to read Mode 6 data on this car)
Mode 6 Information:• OBD Monitor IDs supported ($21 - $40), High sensor voltage for switch time calculation (constant), , Status: Test Fail MID: 20 TID: 04 MIN: - VAL: 0x8002 ✗MAX 0x7FFE
• VVT Monitor Bank 1, Lean to rich sensor switch time (calculated), , Status: ✓
Complete and Pass MID: 35 TID: 06 MIN: - VAL: 0x26 MAX 0x3B
• Oxygen Sensor Heater Monitor Bank 1 - Sensor 1, Lean to rich sensor switch
time (calculated), , Status: Complete and Pass MID: 41 TID: 06 MIN: - VAL: ✓0x63 MAX 0x168
• Oxygen Sensor Monitor Bank 3 - Sensor 4, Minimum sensor voltage for test cycle (calculated), , Status: Test Fail MID: 0C TID: 07 MIN: - VAL: 0xFF97 ✗MAX 0x00
• Oxygen Sensor Monitor Bank 4 - Sensor 1, Minimum sensor voltage for test cycle (calculated), , Status: Complete and Pass MID: 0D TID: 07 MIN: - VAL: ✓ 0x00 MAX 0x02
I really Appreciate all input and advice the community has posted here; Thanks in advance.
Please let me know if anyone needs additional pictures/information
~James
