It is currently Wed Feb 21, 2018 11:07 am
PostPosted: Wed Nov 10, 2010 5:40 pm
Year and Trim: 1998 Bonneville SLE
OK, here's the dilemna. I was driving to work the other day and the red brake warning light came on and started chiming at me. I immediately pulled over to check for a leak or possible broken brake line. No luck. Brake fluid level was ok as well. Started the car back up, and the light was still on but no chime. Put the car back in drive and then it started chiming again. It will not turn off. Everytime I drive the car it keeps chiming at me and will not go off. I put the car in the garage and have been driving my truck. Any ideas what it could be? I drive 60 miles a day to work, and I'm sick of driving my truck
getting 10 mpg.
PostPosted: Wed Nov 10, 2010 5:42 pm
Would the parking brake be partially depressed?? I think that triggers the light too.
PostPosted: Wed Nov 10, 2010 5:46 pm
Not that I know of. I pressed and depressed on it a few times. Even my local mechanic seems to be baffled by it. Is there a parking brake safety switch or something that could have gone bad?
Yup, thats a daily problem I have been dealing with lately. My parking brake cable needs to be adjusted because its way to loose. This causes the parking brake pedal to be floppy and trigger the light if its not in its fully upright position.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Wed Nov 10, 2010 5:50 pm
Pull the parking brake back with your foot and see if the light turns off. Otherwise the switch in your proportioning valve is bad.
PostPosted: Wed Nov 10, 2010 5:54 pm
I've tried that also. Is that switch located in the master cylinder? My local guy just told me that it was the master cylinder itself.
PostPosted: Wed Nov 10, 2010 6:00 pm
Not sure on these cars. On older cars it is a separate valve that if one side's line blows, the valve moves to that side by being pushed from the other side's pressure, sealing off those lines and setting off the light.
There are no new unread posts for this topic. Brake warning light flashing.
MattStrike
Fri Feb 07, 2014 10:33 pm
99BonnevilleSE View the latest post
There are no new unread posts for this topic. Brake warning light & chime, help me diagnose?
Need For Steve
Sat Jun 02, 2012 12:53 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. 96 ssei brake warning light trouble
forcefedbucket96
Tue Jun 26, 2012 5:18 pm
forcefedbucket96 View the latest post
There are no new unread posts for this topic. 1998 Pontiac Bonneville SE: 3 brake lines or 4????
wpbrink
Tue Nov 22, 2016 7:32 pm
There are no new unread posts for this topic. 1998 Pontiac Bonneville SE-- BRAKE line size??
wpbrink
Tue Oct 11, 2016 6:45 pm
96 SSEi View the latest post
