It is currently Tue Apr 16, 2024 12:26 am
Post new topic Reply to topic  [ 9 posts ]
PostPosted: Tue Aug 03, 2010 2:22 pm
Year and Trim: 02 Bonneville SLE
05 Grand Prix GT
Just got done doing the intakes on a 99 Grand Prix. Started right up but idles at 2500. Everything worked before and appeared ok during installation. Any ideas? Thanks, Joe
PostPosted: Tue Aug 03, 2010 4:29 pm
High idle is often caused by a vacuum leak. Check the PCV valve to make sure there is only one o-ring under it and a big one on the chamber top. Look around for hoses or vacuum fittings you may have forgotten to re-connect. Make sure the idle control valve connector is in place.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Wed Aug 04, 2010 4:11 pm
05 Grand Prix GT
Bill, I followed your write up on the intake through the whole process. A great help!
Rechecked again and again all the connections and vac fittings and couldn't see anything. I am wondering about the iac and tps. When I unplug the iac no difference in idle. When I unplug the tps, idle drops down to between 700 & 800 on the tach in park, aroung normal. Once plugged back in it drove normal on a test drive but started to climb again the next time out. TPS problem, and am I ok on the vac leak since it idles fine unplugged?
Thanks, Joe
PostPosted: Wed Aug 04, 2010 4:35 pm
It is possible to get the tang on the wrong side of the spring lever if you disassembled the TPS. But I am not really sure on how to troubleshoot, so, let me get someone smarter to help you, Joe.
Last edited by bill buttermore on Wed Aug 04, 2010 4:38 pm, edited 1 time in total.
PostPosted: Wed Aug 04, 2010 5:01 pm
Did you have the TPS off? If so, take it off again to recheck it. Reinstall the TPS from the 2 o'clock position and rotate into position. check out this video.
Even if the TPS is correctly installed, it might still by your issue. I have dozens here if you need one.
1997 Corvette | 55k | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 95k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 260k | Official Bonneville Hauler
PostPosted: Thu Aug 05, 2010 12:12 am
05 Grand Prix GT
Ok, the tps was in the right position like in the video. This is what happens; I start it and within seconds the idle climbs into the low 2's, next I disconnect the tps and the idle drops to normal, so with it still running I plug tps back in, idle remains good and it operates normal through all driving conditions until it's shut off. Then the process needs repeating.
Without those scan tools and the know how to use them I'm tempted to R&Ring the sensors, or is it time to take it in?
Thanks for the help.
PostPosted: Thu Aug 05, 2010 8:34 am
I'll mail you a spare TPS, PM me your address.
PostPosted: Mon Sep 20, 2010 5:08 pm
05 Grand Prix GT
Sorry I put this reply off for so long, but a big thank you was over due to bill buttermore and harofreak00 for their help with my gasket swap and tps cure. Great write up on the gasket job by Bill and a working tps from harofreak00. The tps worked no more idle problems.
Thanks again,
Joe
PostPosted: Tue Sep 21, 2010 10:01 am
Year and Trim: 2012 Eco
This smells like my issue where my LeSabre will randomly rev up to 2k+ RPM at idle. Darned cheap replacement junk TPS. Time to warranty it at Advance.
There are no new unread posts for this topic. intake gaskets
santonio03
Sun Aug 15, 2010 9:40 am
bill buttermore View the latest post
There are no new unread posts for this topic. L67 intake gaskets?
GeneraL67
15
2184
Mon Mar 15, 2010 12:21 pm
tpulliam79 View the latest post
There are no new unread posts for this topic. Possible symptoms of bad intake gaskets?
93Bonneville
19
5622
Wed Jun 06, 2012 8:21 pm
There are no new unread posts for this topic. intake manifold gaskets
95se
Tue Dec 03, 2013 11:53 am
95se View the latest post
There are no new unread posts for this topic. Lower Intake Gaskets - Again!
SSEBonne4evr
Sun Jan 26, 2014 2:57 pm
SSEBonne4evr View the latest post
Users browsing this forum: Google [Bot] and 8 guests
cron
