It is currently Sun Feb 17, 2019 7:54 am
Post new topic Reply to topic  [ 2 posts ]
 Post subject: temp guage
PostPosted: Fri Aug 06, 2010 11:49 am
Year and Trim: 1997 SSEi
The temp guage on my 97 SSEi went 2 lines past 200 last week while stuck in traffic. It went back to normal (around 200) once i reached highway speed. i had the thermostat replaced and the coolant flushed and replaced. it stays pretty normal except when idling and it creeps up past 200. i put the a/c on and it drops. is there a sensor that makes the fans kick in when the engine temp goes above 200? and if so, where is it located?
Dalimodriva
 Post subject: Re: temp guage
PostPosted: Fri Aug 06, 2010 12:49 pm
Fans come on at 220° unless you turn the AC on, in which case both fans will come on (high speed) at that time. That's the best way to regulate temps, unless you have the PCM reprogrammed for a lower fan turn-on, rewire the system to come on using an added thermocouple and relay, or install a high-speed override fan switch like many of us have.
There are no new unread posts for this topic. Bouncing Temp Guage?
ChevyChugg
Wed Feb 08, 2012 8:47 pm
Bing View the latest post
There are no new unread posts for this topic. trans temp guage...where to buy, hard to install?
Need For Steve
Sun Oct 04, 2009 5:15 pm
slug View the latest post
There are no new unread posts for this topic. Heat? Flashing Temp? Cabin Temp Sensing? ECC Issues!
wjcollier07
14
7709
Mon May 24, 2010 11:01 pm
wjcollier07 View the latest post
There are no new unread posts for this topic. Oil guage in red
Clueless
Thu Dec 22, 2016 7:23 pm
RJolly87 View the latest post
There are no new unread posts for this topic. dash guage
xvr843
Sun Jan 22, 2012 6:03 pm
xvr843 View the latest post
Users browsing this forum: No registered users and 10 guests
cron
