It is currently Wed Feb 21, 2018 10:43 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: Lost Keys - Trunk Access
PostPosted: Sat May 08, 2010 11:34 pm
Year and Trim: 2000 SLE (RIP)
1993 SSEI (RIP)
2008 LS3 Vette
I lost my Keys and need to get into my Trunk :sad5: . The button Trunk Access doesn't work either.
Is there a way to open the Trunk from the inside of it? Do the back seats come out easily?
Also, for a replacement VATS key, I suppose any GM Dealer can get me a new set from just the VIN#?
Thx. -TJ
1993 SSEi Bonneville, Green/Gold Package,NoThermo,5% Tint.
2008 LS3 Vette, K&N CAI (for Z06),DiabloTuned,160Thermo,Flowmasters,5% Tint.
SEE MY RIDES AND VIDEO'S--> http://www.cardomain.com/id/tjnappy
PostPosted: Sat May 08, 2010 11:59 pm
I am curious if they are able to make both keys for you there at the dealer. I wonder if a wiring guru can tell you where the trunk trigger wire is going back to the popper, and you can just hit it with a quick shot of 12 volts and get the trunk open.
PostPosted: Sun May 09, 2010 12:00 am
Can you reach what you need through the rear pass-thru? Unfortunately there isn't a release handle inside the trunk. Even if you remove the back seat, you're not getting a much bigger hole than the pass-thru.
I don't know about the VATS matching.
PostPosted: Sun May 09, 2010 12:09 am
Site Owner/Webmaster
'01 Sierra C3
Where does the truck release wire run thru, and can it be hit with 12v somewhere along it to pop the trunk? I'm guessing the power is cut prior to the trunk release switch, so what it you put power to the wire at the switch?
Owner / Admin
1995 SSEi / 2002 SSEi / 2001 Sierra C3 DENALI
PostPosted: Sun May 09, 2010 12:36 am
Just what I was saying Gordy! Wait! You have a '95 that has an easily accessible harness...
PostPosted: Sun May 09, 2010 12:44 am
'01 Sierra C3
But the trunk button should be easily accessible, and I'm guessing here, but that output of that button may go straight to the release on the trunk latch.
PS: yes, I do now realize I basically said the same thing... lol
Owner / Admin
PostPosted: Sun May 09, 2010 1:19 am
Trunk release button energizes the trunk release relay at the base of the passenger side A Pillar, which then energizes the latch.
PostPosted: Sun May 09, 2010 1:36 am
Year and Trim: 97, 99 Lesabre
I had a locksmith actually make a key for my trunk with no key. It had been lost before I got the car. It wasn't that expensive either.
PostPosted: Sun May 09, 2010 7:41 am
Year and Trim: 10 Silverado
I've had my GM dealer cut keys for a few of my vehicle's with no key (93 Park avenue, 95 Bonnie, 99 Bonnie and a friends 95 Corvette -just the door key for this one). They have never charged me anything extra for not having a key either. :)
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
PostPosted: Sun May 09, 2010 8:17 am
1993 SSEI (RIP)
2008 LS3 Vette
How can one of the back seats be removed? Thx.
PostPosted: Sun May 09, 2010 8:34 am
You have to pull the bottom seat first by pushing in the corners and lifting it. then you will see the nuts that are holding it in at the bottom of the seat back. After you remove them you just need to lift the seat up and out -but there is no since in removing it to try to access the trunk... that won't get you in there. The cutout for the access hole is about all the room you have with or without the seat in there.
PostPosted: Sun May 09, 2010 9:38 am
Does the trunk opener button have an on/off switch inside the glovebox, e.g., so it is turned off for valet parking?
PostPosted: Sun May 09, 2010 10:53 am
Well , I think the big issue is that he doesnt have any key right now. Thus no key on, and no power to the trunk release. Very fine predicament he has created actually.
PostPosted: Sun May 09, 2010 12:37 pm
Year and Trim: 2008 Aura XE
One time I locked my keys in my trunk not paying attention. I keep the lock-out switch in the trunk turned on so the button inside the car doesnt work. After a few minutes of sitting there thinking I went into the woods and got a long branch, pushed my subs around and out of the way and flipped the switch and then I opened my trunk using the switch on the door.
Im not sure if that will work in this situation, as I have noticed with the button on the door that my 92 wont open the trunk unless the car is on, but my 98 will open it without the car on
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
PostPosted: Mon May 10, 2010 3:01 pm
1993 SSEI (RIP)
2008 LS3 Vette
I was fianlly able to get the Keys from that small access in the rear seat. Used a Broom handle to move crap out of the way then rigged a wire hanger to hook the Key ring. Thanks for everyone's help :beerchug: .
PostPosted: Mon May 10, 2010 4:16 pm
Both of my H-bodies have power to the trunk switch when key is off, assuming the lockout switch inside the glovebox is "on."
I'm reading that the Bonneville doesn't have the valet lockout switch inside the car.
PostPosted: Mon May 10, 2010 5:23 pm
Year and Trim: 1996 Bonneville SSEi
- Stock Is A Bad Word -
Mine is in the the trunk by the air compressor controls.
3.6, FWI, 1 Range Cooler, and Energy Endlinks couldn't prevent a spun bearing.
PostPosted: Mon May 10, 2010 5:24 pm
imidazol97 wrote:
Both of my H-bodies have power to the trunk switch when key is off, assuming the lockout inside the glovebox is "on."
Yup.. my 95, 97, and 02 all have power to trunk release with no key in.
PostPosted: Mon May 10, 2010 5:40 pm
My 92 requires the key, and has no valet switch.
PostPosted: Tue May 11, 2010 8:23 am
The topic author has no valet switch, and needs a key to power the unlock solenoid.
Run a 12v jumper from the battery and remove the trunk unlock switch from the door panel. Touch that wire to one side or the other of the switch until it unlocks. Now go retrieve your keys. You can use either a long scrap wire or a jumper cable.
This topic is locked, you cannot edit posts or make further replies. How to access air mix door
haro1225
21
6076
Thu Jul 05, 2012 10:53 pm
J Wikoff View the latest post
There are no new unread posts for this topic. Fuse access
98buicklesabre
Sat May 21, 2011 7:17 pm
98buicklesabre View the latest post
There are no new unread posts for this topic. Access to evaporator, '97? LEAK FOUND!
Bob Dillon
15
1889
Tue Aug 19, 2014 1:18 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. how to access passenger side relay/fuse panel
Billha
Sun Apr 05, 2009 8:24 pm
92BonnevilleSE View the latest post
There are no new unread posts for this topic. I lost my nut
spoiledred94
Wed May 06, 2009 2:57 am
