It is currently Wed Feb 21, 2018 10:55 am
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Fri May 15, 2009 3:02 pm
Year and Trim: 2001 SLE
If you dont feel like spending the 23 bux at corvetteradios.com...i just used the 2 pack of mini lamps at radio shack for behind the display. It was worth a shot for 3 bux and they turned out really good..plenty bright for the display. I noticed too that i used to touch the screen and it used to be quite hot but with the new bulbs in it doesnt get nearly as warm. I ended up doing my whole radio with the 272-1092 2 pack. Ill take pics n show everyone stock and then the radio shack special.
PostPosted: Sat May 16, 2009 8:41 am
Year and Trim: 2000 SE
Nice hack Harro.... :banana:
Just bought a used off Fleabay and lights were out
Bummer, could have done that myself, searched the audio thread, but didn't see this thread
Sent it back, for them to repair, lets see what I end up with 8-[
2000 SE, 17" chromies with 235x55x17 & MXV4+
PostPosted: Sun May 17, 2009 11:58 pm
Year and Trim: 2000 Bonneville SLE, Black
Edit because I found the thread on the old website to refresh my memory:
I replaced mine with 12V incandescent bulbs from RadioShack. Part# 272-1154 for both the lcd display portion and behind the buttons. They're way way cheaper and easier to get. Anyways, everything works perfectly with the cheapo bulbs in there. I used LED's to replace the burned out lights behind my instrument cluster. If I remember right, I used both red and amber for those depending on where they were.
PostPosted: Sun May 24, 2009 8:49 am
Year and Trim: 2000 ssei
What power source did you use to test the lights.
PostPosted: Tue Jun 02, 2009 10:21 pm
All those little red bulbs in the picture, can those be replaced with blue ones? And if yes, which part number from Radio shack would I use? I was thinking of changing all the interior dash lighting to that color and want to know if its even possible. Can that be done to the vehicle display cluster too? HELP?
PostPosted: Tue Jun 02, 2009 10:30 pm
Is this question to me? If so, I just used a standard 12v bench tester.
Those can't be changed. The acutally buttons in the face are red plastic, so if you change the LED's to blue, you would have purple buttons.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Tue Jun 09, 2009 10:30 pm
Hmmm, how about changing the plastic to a blue one then? I thought I read somewhere in these forums that someone had changed all their dash lights to blue ones. That would be nice, well blue is my favorite color. Also, anyone know of any white face gauges for our dashes? I've had no luck finding any and think it'd look nice to have a white face speedo, tach, etc..etc..
PostPosted: Mon Jun 29, 2009 12:46 am
Year and Trim: 2001 Pontiac Bonneville SE
You could look into installing the gauge cluster from the GXP into your car. It has white face gauges.
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
PostPosted: Thu Oct 01, 2009 7:48 pm
Year and Trim: N/A
I only have 1 burned out bulb behind the LCD display. But do I have to order a replacement bulb off that corvetteradios website??? I don't want to pay $23 for 3 bulbs of which only 1 if possible. Could I get the bulbs for the display from Radio Shack?
PostPosted: Tue Jan 12, 2010 1:48 am
Year and Trim: 2003 SSEi Midnite Blue
Thanks for the write up and pics. Had a few out in my radio and thought i'd try it. I bought the lamps from radio shack (272-1092) they worked wonderful. Although i found out it's easier to clip some of the wire off the bulbs so it was easier to get em in the holes due to the fact that the wire is so thin. But that was mostly due to the fact that I couldn't get the solder out. I finally used a needle to make a small hole while i heated it and the wires went right in. Then all i did was reheat the solder and it worked great. :)
2003 ssei Midnite Blue
PostPosted: Sat Feb 13, 2010 8:30 pm
Thanks!
I guess those electronics courses I took when I was younger... and the 5 years employment at Radio Shack finally paid off.
(wifes account name)
They say I have A.D.D but I just don't understa......Oh Look! A Kitty!!
Last edited by PontiacPrincess on Sat Feb 13, 2010 10:12 pm, edited 1 time in total.
PostPosted: Mon Feb 22, 2010 3:31 pm
Year and Trim: 2001 SSEi
THANKS!!!
It seemed like every other week, another bulb died on my stereo. When my CD player stopped working, I bought a junkyard stereo. You know how that goes, security issues make it impossible to swap out the stereo without going to the dealership and spending about $100 to get the stereo to work.
This weekend, I took my stereo out and replaced the CD player with the one from the junkyard stereo. I then took all the bulbs out of the junkyard stereo and replaced all of the ones that were burned out in my stereo.
Worked perfectly. You can replace a defective cassette player and/or CD player from another stereo without causing security problems.
I got the stereo from a U-Pull junkyard for $20.
Now, can anyone tell me how to replace the bulbs in the steering wheel stereo controls?
PostPosted: Mon Feb 22, 2010 3:55 pm
They are actually surface mount LED's, kinda hard to replace for cheap.
I can sell you some mint buttons for $20 if you can't find them at the u-pull.
-Andrew-
PostPosted: Mon Feb 22, 2010 4:27 pm
How do you get to them?
PostPosted: Mon Feb 22, 2010 4:31 pm
Get to what? The switch? Just pull it out? The LED's? Take apart the switch using a sharp prying object.
-Andrew-
PostPosted: Tue Apr 27, 2010 10:07 pm
Year and Trim: 2003 Pontiac Bonneville SLE
the display bulbs are frosted as someone else mentioned. isnt that just a sleeve that slides over the bulb?
2003 Pontiac Bonneville SLE - Sylvania Silverstar Fog lights, 5000k HID conversion low beams, Disabled DRL, cranking headlight delay kit, GXP style exhaust tips, solid front mount. Approx. 86k miles and still kickin strong!
PostPosted: Tue Apr 27, 2010 11:52 pm
There are etched glass versions, and also white rubber sleeves over the bulb versions. You can frost them, or put the sleeves on the new bulbs, but I have found no difference in the display, so I just leave them as standard bulbs.
-Andrew-
PostPosted: Thu May 13, 2010 9:52 pm
Year and Trim: 2000 Bonneville SE
I just did this repair to my wife's 2000 Bonneville today, and it worked great! I sourced all the lights at Radio Shack, since I'm cheap. I just thought I'd ask if the lights in the climate controls were as easily replaceable? The 4 left hand side buttons (front and rear defrost, winshield/feet, and feet) aren't lighting up. Is this a different type of repair, or basically the same thing?
Last Sunday, I replaced the valve cover gaskets. At this rate, I'll have a new car in no time!
PostPosted: Thu May 13, 2010 10:23 pm
In your case, with having an SE, you are able to replace those bulbs easily. It sounds like its the one circled in red:
However, the Dual Zone climate control in the SLE/SSEi is made differently. It is lit entirely by LED's, which rarely go out.
-Andrew-
PostPosted: Sat May 15, 2010 7:31 am
Am I safe in assuming that the disassembly /replacement of the lights on the climate control PCB is as straightforward as it was for the radio?
There are no new unread posts for this topic. 2000 SLE tutorial on changing out power drivers seat?
MrJiggy716
Sat Jul 27, 2013 10:43 pm
This topic is locked, you cannot edit posts or make further replies. the radio light fix 00+
Sat Jun 14, 2008 10:08 am
There are no new unread posts for this topic. My Radio's light bulbs need replaced...
flywelder
Sun Apr 07, 2013 8:41 pm
There are no new unread posts for this topic. Theftlock cd/cassette Radio 2000 SLE
bonne boy
Tue Jun 24, 2008 12:55 am
bonne boy View the latest post
There are no new unread posts for this topic. I will fix your 2000+ radio display bulbs
14898
Thu Nov 10, 2016 1:08 am
ddalder View the latest post
