engine harness damaged http://www.pontiacbonnevilleclub.com/forum/2000-2005-other-than-gxp/topic52239.html |
Page 1 of 1 |
Author: | s0ad [ Tue Apr 09, 2019 11:20 am ] |
Post subject: | engine harness damaged |
On my 2002 SSEi I have damaged wires in multiple locations on the engine harness. On the front 3 fuel injectors, BCS, MAF sensor, cmp sensor. Should I replace/repair each connector, or just get a used complete harness from the junkyard? |
Author: | harofreak00 [ Tue Apr 09, 2019 12:25 pm ] |
Post subject: | Re: engine harness damaged |
Depends what kind of work you prefer, fixing or replacing. I'd guess they will both be the same amount of work required. If you're looking for a good harness I sell them. |
Author: | 96 SSEi [ Wed Apr 10, 2019 1:19 pm ] |
if you use a multimeter with continuity reading, you can do it yourself. you will use the cont. reading to be sure you have no breaks or damaged circuits within the harness. |
