It is currently Mon May 20, 2019 12:38 am
Post new topic Reply to topic  [ 11 posts ]
 Post subject: P0420 wont go away!
PostPosted: Fri Aug 17, 2018 4:31 pm
Year and Trim: 2001 SSEi
2001 SSEi - 84,000 miles
74000 miles Replaced rear O2 sensor
84000 - Replaced Catalytic Converter
84000 - replaced upper O2 sensor
only use sunoco 93 gas(maybe a 92 here and there)
(occasionally use a Lucas bottle/ maybe 1x a year, car ave. 5000mi per year)
P00420 would go off maybe every 1500 miles or so
now, every 120 miles now she puts out the P0420 code
symptoms (only because im really looking due to light)
when under load (climbing a hill) and if RPMs are around 1200 she sounds like shes struggling, like i have to give it a lot of gas, soon as i press on gas she goes
gas mileage is about 15.8 in town
will update if i see more
 Post subject: Re: P0420 wont go away!
PostPosted: Fri Aug 17, 2018 7:56 pm
some info for you in between code resets
http://www.easterncatalytic.com/educati ... 420-codes/
https://www.obd-codes.com/p0420
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
PostPosted: Sat Aug 18, 2018 12:51 am
What cat did you put in?
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod | garage queen
2005 Town & Country Limited | Butane Blue Metallic | 290k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 210k | Official Bonneville Hauler
PostPosted: Sat Aug 18, 2018 12:27 pm
I don't know, I paid to have someone do it and they ordered the part.
I took it to my regular mechanic to have things assessed.
He said looks like an aftermarket "performance" cat was used. The code is most likely due to the cat.
He suggested eiter remove this one and put on a OEM replacement, or buy a tuner and ignore the P0420 code. (as well as enjoy other benefits of tuner)
He said the current cat is not harming the car.
feedback?
PostPosted: Sat Aug 18, 2018 1:28 pm
what?, the guy who installed it doesnt know what he installed - call him and get the order reciept/invoice. you need a 50 state legal cat or the cali/Canadian one to avoid issues
no I dont believe that any harm will be done , but, you're not going to pass emissions with the code
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
PostPosted: Sun Aug 19, 2018 11:23 am
If necessary, you could go the route of an emulator.
https://zzperformance.com/3800/o2-emulator
PostPosted: Mon Aug 20, 2018 10:58 am
Since it struggles up hills, it makes me think you have some kind of ignition system issue. Is there any other indication of troubles? Does it feel good when you're WOT?
"Penelope" - 2003 SLE - 187k Miles
"Sydney" - 2000 Honda S2000 - 61k miles
PostPosted: Mon Aug 20, 2018 11:06 am
You need a name brand Heavy Metal catalysis, he probably put in a cheap Chinese piece of junk and charged you for a good one.
I recommend the Magnaflow 99306HM (around $100 online), I install them on all my project cars, never had them throw a code.
-Andrew-
PostPosted: Mon Aug 20, 2018 11:43 am
Thanks for the recommendation.
PostPosted: Wed Aug 22, 2018 12:30 am
Year and Trim: 03SSEI, 00SSEI, 92SE(sold), 93SSE/SC, 87GTA, 01TA
I have had ignition problems cause a P0420 before.
With your mileage, if your plug wires are original you may want to consider changing them and also check plug gaps.
PostPosted: Wed Aug 22, 2018 7:28 am
at 60000miles i had new plugs wires done
There are no new unread posts for this topic. P0420
DASHAWN1234
Sat Feb 09, 2013 1:37 pm
DASHAWN1234 View the latest post
irish91983
Mon Jul 09, 2012 11:17 pm
irish91983 View the latest post
EWC88
Mon Oct 19, 2009 7:31 pm
EWC88 View the latest post
There are no new unread posts for this topic. P0420 out of nowhere...
SSEiMan01
12
2383
Wed Nov 16, 2011 5:04 pm
SSEiMan01 View the latest post
There are no new unread posts for this topic. Code P0420
SSEI173
Wed Feb 13, 2013 7:49 pm
SSEI173 View the latest post
Users browsing this forum: No registered users and 10 guests
