PontiacBonnevilleClub.com
Code 0303
http://www.pontiacbonnevilleclub.com/forum/2000-2005-other-than-gxp/topic51784.html
Author:  57j2olds [ Tue May 29, 2018 10:06 am ]
Post subject:  Code 0303
Hello,
I have developed a horrible mis-fire and code P0303.
Before I start throwing money at this 2001 SE, can you recommend a no cost route?
It's worse when its humid or wet outside.
I have read that it could be:
Bad coil
Bad plug
Bad wire
Bad ICM
Thanks in advance.
Lee
Author:  96 SSEi [ Tue May 29, 2018 12:27 pm ]
Post subject:  Re: Code 0303
first see if the wire boot is seated on the #3 cylinder properly - follow the wire from the coil that is marked 3 to find 3 cylinder and plug.
Author:  nos4blood70 [ Tue May 29, 2018 2:15 pm ]
You can always move the coils around and see if the misfire follows, same goes for similar length wires.
Author:  57j2olds [ Fri Jun 01, 2018 8:45 am ]
I ohmed the wire on cylinder number 3 and it read infinity. Swapped it out and miss is gone.
Thanks.
Author:  nos4blood70 [ Fri Jun 01, 2018 9:39 am ]
Good to hear!
http://www.phpbb.com/
