It is currently Mon Feb 18, 2019 3:11 pm
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Fri Aug 11, 2017 8:11 am
Year and Trim: 2001 Bonneville
Hello,
I think my rear compressor for the shocks is no longer working on my 2001. Has anyone had success with the conversion kits out there to eliminate the air ride?
Also, when the car is first started it idles high in drive (gear).
I can go about 20-25mph without touching the gas.
Any clues what I should check first?
Thanks,
Lee
PostPosted: Fri Aug 11, 2017 12:26 pm
Year and Trim: 1992 SSE
Take the air intake tube off, and the maf screen if you can, and see if the throttle plate is gunked up and not fully closing. Or the idle air control valve could be binding. Take it out, clean it with some throttle body cleaner. Hold the throttle plate open and hose that down with the TB cleaner spray too.
WHITE WHINE - IT'S INTOXICATING. 1992 SSE Supercharged 236.26 ci (.040 Over)
15.090 at 90.2 MPH on old engine w/ slipping trans & melted O2 sensor - Gen 3 M62 and matching TB, Gen 2 Pully, Zillamotorsports Ported LIM, YT 1.72 Roller Rockers, SII FPR & Injectors, Easy Performance Gen 3 Air/Fuel Calibrator, Hypertech Thermomaster chip w/ 160 Thermo, TransGo Shift Kit, Infinity/Pioneer Speakers and 10" Subs, 1300 watts, 140 amp Alternator, Ricepipe CAI w/ heatshield, Pilot Angel Eye Foglights, Clear Corners, '02 17" Chrome Bent 5's, Magnaflow F-Body Muffler and Hi-flo Cat, McCoy Motorsports Ceramic Coated Ported Exhaust Manifolds, Fan Override, PowerSlot Slotted Rotors.
2009 G8 GT - Sport Red Metallic, loaded, SOLO Axlebacks, Rotofab Intake, Tuned, autodim Trailblazer mirror, removed intake manifold cover, HSV GTS triple gauge pod, two tone red-hot shifter and HSV SuperSport steering wheel, GXP rear sway bar and diffuser
PostPosted: Fri Aug 11, 2017 1:24 pm
Thanks.
I will try this weekend.
PostPosted: Fri Aug 11, 2017 11:31 pm
best to have a rag handy to soak up the solvent over-spray - I killed a cat by dumping tb cleaner while running.
keep the engine off while cleaning - you can also jack up the car on pass side so the over-spray will drain out the TB opening to your rag
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
There are no new unread posts for this topic. 2001 SE Hard starts, poor idle
lowrider0308
Fri Dec 19, 2008 9:16 am
There are no new unread posts for this topic. High idle and Cruise 'idle'...
Z-type
11
3061
Mon Jul 25, 2011 11:14 pm
Z-type View the latest post
There are no new unread posts for this topic. Poor Mileage / Bad o2?
silverws6ta
Thu Jun 17, 2010 2:21 pm
silverws6ta View the latest post
There are no new unread posts for this topic. Poor Mileage after Battery Run-Down
malatu
11
3202
Sat Dec 27, 2008 4:57 pm
wjcollier07 View the latest post
There are no new unread posts for this topic. Poor Radio Reception?
Fri Oct 09, 2009 12:02 pm
harofreak00 View the latest post
Users browsing this forum: No registered users and 10 guests
