It is currently Wed Feb 21, 2018 11:00 am
 Post subject: gas pedal sticks
PostPosted: Sun Jun 17, 2012 2:02 pm
Hi I have a gas pedal that will not allow light pressure for light acceleration, then when I press it more it snaps in place but then there is too much acceleration. I never really heard of this? Needs a lube job?
 Post subject: Re: gas pedal sticks
PostPosted: Sun Jun 17, 2012 3:48 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Have you removed the throttle body to clean it? The butterfly can get pretty gummed up.
PostPosted: Sun Jun 17, 2012 10:14 pm
Also make sure the spring on the outside of the TB is not dirty and gummed up.
PostPosted: Sun Jun 17, 2012 10:20 pm
IMO, its not really necessary to remove the TB to clean it. Just remove the air intake box and the MAF screen. Spray some carb cleaner in the TB, then open the butterfly valve and use an old toothbrush or something similar to scrub the buildup away. Don't worry about making it spotless, you are just trying to remove the ridge where the butterfly valve is getting stuck. Use a rag or something wrapped around the toothbrush to wipe away all the crud. Put the screen and intake back in place.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Mon Jun 18, 2012 11:24 am
That was my thought as well looking for an easier way. After cleaning it out almost three years ago during my intake tear down, mine is starting to stick again.
PostPosted: Mon Jun 18, 2012 6:33 pm
Ok thanks, I thought was pretty recent that I cleaned it as well but it sounds like you guys all agree. Makes perfect sense. Thanks again.
PostPosted: Thu Jul 12, 2012 8:45 pm
Took it out and cleaned it right this time, good to go. Thanks.
There are no new unread posts for this topic. Steering sticks then hardens then breaks lock up
Castro
Mon Apr 08, 2013 4:50 pm
Castro View the latest post
There are no new unread posts for this topic. Gas Pedal Depression
01BonnnivilleSE
15
1324
Tue Nov 15, 2011 2:04 pm
01BonnnivilleSE View the latest post
There are no new unread posts for this topic. Gas Pedal Firmness
Hans
Thu Nov 17, 2011 2:10 am
There are no new unread posts for this topic. gas pedal vibration
samples08
Sat Apr 06, 2013 10:32 pm
DaMaroon View the latest post
There are no new unread posts for this topic. Hard brake pedal.
n/a silver bonne
Tue Dec 15, 2009 6:27 pm
