Transmission Shopping
- leatherneck
- SSE Member
- Year and Trim: 2002 SLE
Ok guys and gals... I am shopping for a transmission for my '02 Bonneville. Aside from the different gear ratios... (mine has hte 3.05 in it) all the ones I seem to find are for the 2.86, asisde from this I have a few questions....
I am finding 4T65E's for various models other then the Bonneville... Are there any "catastophic" differences in these? I know that when I was engine shopping that I almost went Series III instead of the II but in this case I am looking for something with fairly low miles and age, but the car is 10 years old now.. So do I have to use hte Bonneville trans or can I put one say out of an 06 Monte Carlo or other 4T65E application?
Next question... Can I just reuse my diff out of my transmission or is there more sinister forces working against me to get the proper gear ratio?
I plan to buy this week as I really need to get my car fixed ASAP...
2002 Bonneville SLE 128k miles aka "Frankenbonnie"
Intense PCM w/2004 improved trans shift points/180 fans-stat/+3deg timing advance/DTC inhibit
Transmission Cooler
Upcoming changes - Hi Flow Cat/Exhaust - Cold Air Kit
1993 GMC 'Burb aka "Zombie Assault Vehicle" 230k miles
Transmission Cooler
Re: Transmission Shopping
You need a trans that matches your trans tag, whatever that may be. It must come from an 00-02, maybe 03, Park Avenue, LeSabre or Bonne w/ 3.05 gears, for a perfect match. Otherwise I'm not sure what else will work comparatively.
- leatherneck
- SSE Member
Well it looks like I have found the transmission... just have to wait to get paid, picked up and installed
hope its still there when I go to get it...
Transmission Cooler
Transmission Cooler
deano55
- Posts like an L36
- Year and Trim: 2003 Bonneville SSEI
are these trans's going out at 128K??
- leatherneck
- SSE Member
That seems to be the pattern I have been seeing here as of late...
Previous owner of thes car needs to be located and lynched for its treatment.
Transmission Cooler
Transmission Cooler
- leatherneck
- SSE Member
I have decidede to attempt to swap in a trans out of a 2004. Doing some research I know that there are differences in the way the transmissions talk to the PCM. So I talked our friend John at Intense and have a PCM on the way with the 04 information programmed into the PCM with all else being 02 programming.. and since I had to pay for the custom tune package I took the liberty of having a few other changes made to the engine tune as well. I paid for Saturday delivery so hopefully that shows up today
The swap starts later today and hopefully I will get this in today. This is my first trans swap in a FWD car and looks like it is a really fun process.... But at a total cost of less than $800 for everything including the new seals, trans filter, trans cooler, mounts, fluid, the PCM and the Trans itself... Its much better then the $2,600 the trans shop wanted... Providing that all works as planned....
And if it dosen't work well, I saw a G8 for sale yesterday...
Transmission Cooler
Transmission Cooler
- leatherneck
- SSE Member
Ok I have the car on jackstands, the front tires are off... and as I am looking at the way this is installed at some point I am going to have to drop the subframe to get the trans all the way out due to the location on the drivers side and the engine being in the way.
I have my jackstands located on the front part of the subframe, but this looks like I am going to need to relocate these elsewhere, but I am not 100% sure as to where to put them so they do not damage the car.
Transmission Cooler
Transmission Cooler
01bonneSC
Def something I wouldnt want to do without a lift lol. And dont forget pics!!!
- leatherneck
- SSE Member
I am def takin pics... just a matter of finding placement for the stands... and I would probably have the old one out by now if I had a lift
The link to the process so far is below... more to be added
http://photobucket.com/bonnevilletransmission
Transmission Cooler
Transmission Cooler
1oldman
wish I was there to hand you tools and to watch and learn - lol - BC
