It is currently Thu May 28, 2020 6:19 pm
Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sun Jan 22, 2012 6:05 pm
Year and Trim: Currently searching for a Bonneville...
I wish I could kick whoever's idea it was to put a hundred incandescent bulbs all over the dash, then solder them in place so they can't be switched out. What morons.
Does anyone know what bulb I can use to replace these? The ones in my brightness control, and now my HUD controls are dead, along with some in the radio (of course). I assume I'm going to have to unsolder and resolder new ones in..? I'm tired of buying replacement switch assemblies from the junkyard, only to have them not work, or burn out in a matter of weeks. Ugh.
PostPosted: Sun Jan 22, 2012 8:12 pm
Same bulbs as you find in the radio. The link is in the common problems and solutions thread. http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?f=18&t=7188
PostPosted: Sun Jan 22, 2012 8:35 pm
Any chance of using LED's? I know LED's polarity has to be correct or they will not work. I have seen some for sale lately that are "bi-polar" - lol. I think the LEDs look better too. - BC
2017 Hyundai Santa Fe Sport ..... 1992 Bonneville SSE 1SB 170 HP L27 4T60E retired/sold to MattStrike ..... 2005 Bonneville SE 1SC 205 HP L36 4T65E - retired/salvage yard ..... 2013 Cadillac CTS 1SD 270 HP LF1 6L50 - SOLD ..... PBCF user 2321
PostPosted: Sun Jan 22, 2012 8:40 pm
12 volt leds are not widely available, especially white ones. It'd be a real tight place to stuff resistors into.
PostPosted: Mon Jan 23, 2012 9:00 pm
When I looked at everything last, it seemed to me that I might be able to squeeze a 5mm white LED and a 1/4 watt 470 ohm resistor laid transversely to the LED. I have been looking for information on either the polarity of the lights or on the pins for illumination on the harness so that I can check it myself. The switch he pictured would be easy to put an LED onto in the manner I described.
Those "Bi-polar" led modules you are thinking about are made using some other hardware that you would not be able to fit. There are also LEDs that accept voltage in 2 different direction, but those are generally low power LEDs that are made to change color when polarity changes. But on your 92, changing bulbs out to LEDs should be easy. Almost everything uses replaceable bulbs.... The HUD uses a cold cathode, so you are gonna have to forget about that, and the switches should leave room for a 5mm LED and a creatively oriented resistor.
There are no new unread posts for this topic. I'M REALLY STARTING TO HATE THIS CAR
bslayer
Mon Dec 06, 2010 6:52 pm
There are no new unread posts for this topic. bulbs for dash
johnrich
Wed Mar 05, 2014 1:02 am
There are no new unread posts for this topic. Bulbs out, can be replaced?
EWC88
Sun Oct 05, 2008 5:26 pm
EWC88 View the latest post
There are no new unread posts for this topic. 2005 SLE Fog Light Bulbs
dougtoth
Sun Aug 26, 2018 12:01 pm
There are no new unread posts for this topic. Dash lights,are there bulbs?
charged
Tue Dec 23, 2014 8:32 pm
Users browsing this forum: Google [Bot] and 15 guests
