It is currently Wed Feb 21, 2018 10:57 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 16 posts ]
PostPosted: Tue Jun 07, 2011 12:10 am
Making this tutorial for a friend.
Locate the MAF sensor. It is directly on top of the throttle body.
It has 2 screws hold it in.
You'll need a T-20 Security Torx bit. The security bit has a hole in the middle. A regular torx bit will not work.
Remove the screws
Disconnect the electrical connection on the underside with a flat blade screwdriver
Look through the hole in the MAF and you'll see two tiny wires with a gray filament on them. These wires detect how much air is going into the engine. If they are black/brown that means they are dirty and not giving the proper readings. They need to be cleaned.
Using some Mass Air Flow Sensor cleaner,
Spray the filament for 3-4 seconds. If it still doesn't get clean, VERY carefully use some Q-tips and wipe them off. Then spray again.
Reinstall the MAF in the reverse order.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Tue Jun 07, 2011 11:04 am
Thanks Haro. I didn't ask about it but glad I checked this out.
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
PostPosted: Sun Jun 12, 2011 11:35 am
Year and Trim: 2002 Bonneville SLE
Another satisfied customer with this maintenance tip!
One thing to point out - I was at Pep Boys looking for the Torax -20 Security bits and no one knew what I was talking about. I looked at the tool section and didnt see anything with 'security' written on it. I went to look again and this time looking at the end of the bits - they had these Torx bits but they were labeled the same as the others.
Anyhow - look at the bits if you dont see anything labeled 'security'.
This was truly a 5 minute operation.
PostPosted: Sun Jun 12, 2011 1:03 pm
When I did mine, I used a vice-grip to remove the bolt, then replaced them with M1x2.5 allen head capscrews. Now it's even simpler to remove & replace.
PostPosted: Fri Nov 23, 2012 7:50 pm
Year and Trim: 2000 Bonneville SE
Thanks for a most informative MAF R&R, and service pictoral guide!
FYI, the T-20 Torx Bit with tamperproof feature is now designated the "TT-20"
Lowe's sold me one for under $4.00, 1/4" drive.
mrwildroot
PostPosted: Fri Nov 23, 2012 8:22 pm
I just threw down for one of these:
http://www.harborfreight.com/100-piece- ... 68457.html
I haven't met a screw yet that I couldn't unscrew.
PostPosted: Fri Nov 23, 2012 8:45 pm
Year and Trim: 2002 Now DOA and rear ended like a pig on a spit
Good basic maintenance tips are always appreciated!
Buy the best and you'll only cry once... Or so my therapist tells me....
PostPosted: Fri Nov 23, 2012 8:55 pm
Year and Trim: Pullied Clean 2k Black SSEi...
Pulled many a MAF without the bit. A small flat screwdriver placed right, and a quick tap via hammer will break the pin off clean. You then never need the security lock torx bit again.
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Friends don't let friends use Pep Boys lol.
Also I would know what a Torax bolt is either. But they should have been smart enough to know that you meant Torx size 20. The security part is the hole in the end.
Mods, maybe make this a sticky or in the TechInfo Pages?
PostPosted: Fri Nov 23, 2012 11:47 pm
...Now you tell me...
mrwildroot
PostPosted: Fri Nov 23, 2012 11:54 pm
89 SkiDoo
Everyone should have a security Torx set, requires 2 less tools... I.e. hammer and screwdriver...
PostPosted: Mon Dec 10, 2012 2:02 pm
So I got into the project this weekend. I have a K&N Air Filter that was ready for a good cleaning, a can of MAF Spray Cleaner, and the TT-20 Torx tool.
The directions above were invaluable, and so the entire project went very smoothly...
I can't describe the increase in power to the wheels! Even the tranny shifting anomalies vanished!
I'm watching the mileage/fuel ratio to see if there is some improvement there as well.
So, for the cost of a K&N Refurbish kit, a can of MAF cleaner, and a $3.50 tool, I have a like new car!
I highly recommend the 10 minute MAF Sensor cleaning to all fellow Bonnie owners!!!
Thanks,
mrwildroot
PostPosted: Thu Dec 20, 2012 4:40 pm
Year and Trim: 2001 Bonneville SSEI (3800 Supercharged)
Does MAF Sensor Cleaner have to be used? Or will something like brakleen work?
PostPosted: Thu Dec 20, 2012 4:45 pm
89 SkiDoo
MAF Sensor cleaner should be used. Its no where near as harsh as brake clean.
PostPosted: Fri Jan 20, 2017 10:41 pm
Year and Trim: 2001 Bonneville SLE
I pulled the MAF and it looks like new. Now what?
PostPosted: Sat Jan 21, 2017 6:45 pm
Replace it.
-Andrew-
There are no new unread posts for this topic. ABS code 'C1245-Acceleration Sensor Output'-sensor location?
Teearohwhy
Fri Dec 14, 2012 12:37 am
Archon View the latest post
There are no new unread posts for this topic. clogged fuel injectors / how to clean
Oldman
Tue Aug 17, 2010 10:11 am
1fatcat View the latest post
There are no new unread posts for this topic. Cascade dishwasher detergent to clean out radiator?
ytd1861
Sun Jun 09, 2013 6:18 pm
ytd1861 View the latest post
There are no new unread posts for this topic. Crank Position Sensor and Cam Position Sensor
01bonneSC
Fri Nov 28, 2008 2:37 pm
There are no new unread posts for this topic. Air bag sensor
BonnevilleBill
Wed Mar 11, 2009 6:31 pm
Gumball View the latest post
