It is currently Mon Feb 18, 2019 8:18 pm
Post new topic Reply to topic  [ 2 posts ]
PostPosted: Fri Dec 17, 2010 11:27 pm
Hi All,
My 'Service Engine Soon' light came on just recently & I drove down to Advance Auto Parts to have the fault code revealed. I was told it was a coolant / temperature sensor code.
Can somebody very specifically tell me where this sensor is located? The car is a 2000 SSEi. I've looked on the web and the descriptions are vague.
Somebody please specifically tell me where I
can find it. Pictures would help, if available too.
Thanks.
PostPosted: Fri Dec 17, 2010 11:57 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
can't find a good pic, but it is easy to find. follow the upper radiator hose (right side, standing in front of engine) to the engine. move your hand down 4 inches, you will run into a small wire harness plugged into the engine. that is the coolant temp sensor. it is the only wire in that area. it is up and to the right of the front exhaust manifolds right end.
There are no new unread posts for this topic. Air Temperature Sensor
a20h
Thu May 14, 2009 12:02 am
a20h View the latest post
There are no new unread posts for this topic. ambiant temperature sensor
2005 pontiac
Tue Jun 05, 2018 4:39 am
ddalder View the latest post
There are no new unread posts for this topic. oil pressure and coolant sensor test. questions...
mrrcom
Fri May 16, 2014 5:21 pm
mrrcom View the latest post
There are no new unread posts for this topic. 2005 SE Coolant Temp Sensor location
Mac077
Thu Apr 07, 2011 3:11 pm
harofreak00 View the latest post
There are no new unread posts for this topic. Engine Coolant Temp Sensor Question
NWASSEi
25
3764
Sat Jan 17, 2009 11:36 pm
NWASSEi View the latest post
Users browsing this forum: Exabot [Bot], Google [Bot] and 9 guests
