2002 bonneville se
plehmann16
- LE Member
- Year and Trim: 2002 Pontiac Bonneville Se
2002 bonneville se
looking for where blend door actuator is located, have just one temp control
Re: 2002 bonneville se
Hopefully these pics will help.
- Archon
If your looking for the air-mix actuator for adjusting the temperature, it's this one.
plehmann16
- LE Member
thanks for taking the time to help, I will give it a shot today, the fan runs but I have no heat. It is the same with the air cond. that was checked and had plenty of juice but nothing on the inside of car.
Thanks again
Thanks again
plehmann16
- LE Member
I took off the air mix activator and manually twisted the door and I now have heat. I then opened the actuator and applied current to the motor and it turned, reversed the leads and it went the other direction. I am guessing that the actuator is not getting any current from the temperature dial on the dash. Do I need to find a used heater/ac control?
plehmann16
- LE Member
Nope, did not solve the problem. I am starting over with the ac. The compressor was not turning so we figured maybe the ac pressure switch (3 wire) and replaced it. No good. Going to recheck the 134a. Which actuators would control letting the ac in?
- Trinity
- GXP Member
- Year and Trim: 2002 SSEI "Twitch"
Intense LIII - Location: IL
2002 Bonneville dual zone and am looking for the air mix actuator, it's failed and I only have a bit of heat on drivers and pass is blowing cold as hell. For now I just want to manually move it to full heat for the winter. In the spring I will look into the issue.
The image posted above no longer works as this thread is very old. Could someone shoot me a picture of which one I need to go after?
Thanks!
JT
Thanks!
JT
2002 SSEI "Twitch"
INTENSE™ Fenderwell Intake Kit
INTENSE™ Modular Pulley System with 3.40" Pulley -
SD Headers H-Flow Cat
WB 255 Siemens 60.0 (65.0) pound/hour Fuel Injectors
Yella Terra 1.9 90# Manley Retainers
L32 LIM & Gen V Blower N* TB
- nos4blood70
Archon would be the guy to PM, I'm sure he still has it somewhere.
- Trinity
- GXP Member
nos4blood70 wrote:Archon would be the guy to PM, I'm sure he still has it somewhere.
Thanks Carl! I stumbled into Haro's thread on common problems:
http://i675.photobucket.com/albums/vv11 ... airmix.jpg
http://s675.photobucket.com/user/bon2k2 ... x.jpg.html
Love this forum!!
JT
2002 SSEI "Twitch"
