It is currently Wed Apr 25, 2018 4:33 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Help!!! Water in trunk
PostPosted: Tue Sep 23, 2008 6:29 pm
Year and Trim: 2011Taurus SHO
I know that the 2000+ models can have problems with water in the trunk. Has anybody found the cause of this? I drove my car from Kalamazoo to Grand Rapids in all that rain we had a about a week ago. I knew there had to be water in the trunk because I was getting condensation in the car. I fell and broke my leg the day that it rained the hardest so today was the first time I was able to look. Go figure, there was about 3 inches of water in the spare tire well. That was not fun to clean out with my leg in a cast but it had to be done. Now I need to check under the carpet in the backseat to see if there is water there. If anybody can tell me how to solve this problem it would help a lot. I'm not sure how much I can do with my leg but I need to get to it ASAP.
2011 Ford Taurus SHO, Livernois Motorsports Stage 4x+ tune, 3 bar MAP sensor, Motorcraft SP534 plugs, 160* Tstat, best ET 12.5612@ 108.96 MPH running 0.75 gallons of E85 to 13 gallons of 93 octane, 35% tint, 2013+ fender badges! debadged trunk and rear quarter window
2008 Grand Prix GXP Dark Red, Magnaglow Cat Back, Overkill Motorsports Tune, K&N FWI, 20% tint, 6,000K HID lows, 5,000K HID fogs and HIR highs (sold)
2005 Greystone Metallic, cleared corners, 20% tint, drop in K&N filter with gutted air box, 6000k HID low beams and fog lights, LED interior lights and reverse lights (sold)
PostPosted: Tue Sep 23, 2008 6:37 pm
Check the tail lights, reflector on the trunk, spoiler, and trunk seal. Easiest to climb in the trunk with a flashlight and close it and have someone spray the car with a water hose
PostPosted: Tue Sep 23, 2008 6:51 pm
I think Darcy had it narrowed down to coming in from either a plugged sunroof drain or the rear shock towers. It only happens with hard rain and it never gets wet from washing the car.
PostPosted: Tue Sep 23, 2008 6:53 pm
The sunroof usually leaks in on the carpet in the back seat. The trunk leaks will cause water to roll past the back seat into the carpet.
PostPosted: Sun Sep 28, 2008 11:02 am
An addition to the list that myfirstbonnie gave, add the seal around the 3rd brake light. All those things were listed in a TSB regarding trunk leaks.
PostPosted: Wed Oct 08, 2008 11:34 pm
Year and Trim: 95 SSEi
05 GXP
My trunk leak on my GXP was from the CHMSL or third brake light.
Here is a picture. You can see that someone in the factory didn't seat
it properly in the hole. The rubber seal was pinched and misaligned.
Mine didn't leak from washing either. I think driving it in rain pulled water
into the light from the wind flow over the deck wing.
Once I fixed that, no more water in the trunk.
Black 95 SSEi (original owner) 236K miles
Black 05 GXP (some idiot put the first 12K on it)160K miles
Black 04 Tahoe (original owner)264K miles
Black 16 Traverse (original owner)30K miles
PostPosted: Wed Oct 08, 2008 11:35 pm
mine was just the seal
PostPosted: Tue Oct 21, 2008 10:56 am
Try and take out the carpet in the trunk and make sure if you have a sun roof that the hoses are not clogged and that the hoses are connected to flow out in the trunk. When I was rear-ended the dealer who fixed my car never reconnected my hose so that the water could flow out from my sunroof to the back.
Have any questions call me 863-521-2440
Garrett A> Lombardi
PostPosted: Sun Feb 22, 2009 6:11 pm
Year and Trim: 2001 SSEi
I also recently started have water in my trunk, and found the sunroof drain hose on the left side of the trunk was disconnected. I am not sure how this happened, but I just reconnected it today and I will let you know if it stays dry after the next rain.
I hope this helps.
2001 SSEi 133,000, Intense FWI, ZZP SS Headers, S1X Cam, ZZP Aluminium Heads, 3.2 Intense, GenV, 180 Stat, 42#, WB O2 LC1, HP Tuner Pro, ZZP tranmission.
PostPosted: Sun Feb 22, 2009 11:03 pm
Banned
Year and Trim: 05
Bolts that hold the GXP spoiler on have been an issue as well with some missing the seal washer.
PostPosted: Mon Feb 23, 2009 12:04 am
I pulled out all the trunk carpet the other day and it looks like it is coming from the top of the drivers side shock tower.
PostPosted: Wed Feb 25, 2009 12:47 am
The only thing 'up there' is the trunk lid seal itself.
PostPosted: Wed Feb 25, 2009 1:08 am
could very well be the problem, that's what mine was. try the climing in the trunk and having someone spray it with a hose, it works great to pinpoint it
PostPosted: Sat May 09, 2009 9:16 am
Year and Trim: 2004 GXP
I just fixed leak number 3 in my Bonneville (number 2 in the trunk). Leak number one was the right side shock tower. I sprayed undercoating around the spot it comes up through the wheel well. Leak number 2 in the trunk was a big one. I had about 2 inches of water in the spare tire well. Turns out it was coming from a seam on the drivers side. A piece of engineering brilliance (not) from GM. There's a hole in the trunk floor and side of car where the gas filler goes through. The entire area is covered with a metal cap and held in place with sealer. The seam was leaking. As you can see from the pics, on the wheel well side, there is zero sealer. There's a plastic access cap inside the wheel well. If you remove it, you can see the inside of the opening which is capped off inside the trunk. I put seam sealer all over the factory seam and cleaned all the gravel and mud from the wheel well side and sealed that also. You can see in the one pick along the base of the shock tower where the factory missed the seam entirely! I sealed that also, even though it didn't appear to be leaking. Looks like the union worker hit the end of the tube and just left it. Great quality control guys!
Here's a couple of the pics I took.
Pic 1 - pic of where factory missed a body seam entirely
Pic 2 - pic of where water was just flowing in from the factory seam holding cap in place
Pic 3 - View of cap from the wheel well side - no sealer from the factory at all
PostPosted: Sat May 09, 2009 3:01 pm
I had noticed the water leak around one of the shock towers. The other location was one of the threaded studs that secure the black plastic trim in place across the outside of the car at the opening to the trunk. These studs are held in place by melting the plastic trim around them. One pulled out and when it did, the stud was loose in the hole. This allowed water to pass around it and into the trunk when it rained or otherwise got wet. This has been a problem in both my 2K+ Bonnevilles.
PostPosted: Thu May 14, 2009 1:51 am
Year and Trim: 2006 Cadillac STS-V, 2004 Pontiac GTO
Mine is from the sunroof. I tried to reseal it to no avail. I eventually fixed mine by drilling two small holes into the spare tire well at the lowest point and added a touch of paint to the hole edges with a q-tip.
No problems ever since. I figure if you can't beat it, let it do what it's gonna do, let it drain, and therefore no musty odors in the trunk, or risk of getting trunk items wet (which I've never had issue with).
PostPosted: Wed Jul 08, 2009 11:15 pm
I did the same thing. I drilled two holes and sprayed them with etching primer and once that dried I put some paint around and on the edges of holes with a Q-tip.
I'm with you when it comes to letting it happen but let it drain as well.
PostPosted: Sun Jul 12, 2009 12:46 am
Great minds think alike. :)
PostPosted: Thu Jul 23, 2009 11:43 pm
aren't there already holes there? they are just plugged with some rubber grommet things which i removed.
PostPosted: Fri Jul 24, 2009 12:13 am
I don't believe drainage holes are the answer. They may keep water from accumulating but doesn't prevent moisture presence in the passenger area or trunk (depending on where the leak originates). Obviously there must be a solution because not everyone's car has a leak. Long term there's just going to be more problems unless it's fixed correctly.
If the source is unknown I would try a leak detecting powder. If the source is known I'd obtain the right parts (as needed) and spend the time to tackle the problem.
There are no new unread posts for this topic. Water in car
blubyu
Wed Jul 30, 2008 10:35 pm
skregal View the latest post
There are no new unread posts for this topic. Water in Car
mblaze
Mon Jul 06, 2009 1:41 am
There are no new unread posts for this topic. Water Leaks... Ugh!
ddalder
21
1886
Sun Mar 01, 2015 7:50 pm
There are no new unread posts for this topic. Water pump replacement
sethjamesrimrodt
Wed Oct 17, 2012 10:07 pm
dpnewfie View the latest post
There are no new unread posts for this topic. water outlet housing
All Things Gxp
Mon Dec 31, 2012 12:47 am
All Things Gxp View the latest post
