It is currently Fri Apr 20, 2018 4:25 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: Tue Aug 03, 2010 1:03 pm
1997 Oldsmobile LSS L67 - SOLD
I need to get my cluster sent in to be overhauled. Just wondering what is involved with removing it. Is it safe for the worlds worst mechanic to try it? :)
Also, is there any difference between the GXP cluster and the regular one? Just gauge colours?
Thanks
2004 GXP - Greystone and stock
95 Oldsmobile 98 L36. 180 degree thermostat. Tru-Cool tranny cooler. Touring Sedan wheels. FE3 springs. Urethane End Links. Magnaflow Cat 94006 -> Soon to be replaced by something that works. WAI. Ported and polished LIM.
Mods coming soon - . Touring Sedan seats. TS Sway bars. - Sold
97 Oldsmobile LSS L67 - Stock. For now. - Sold
PostPosted: Tue Aug 03, 2010 1:29 pm
No wrenches involved, Erik. Find the instructions for removing the bezel, then push the gold tabs over on the cluster and it should pop right out. Some pulling while pushing the tabs is required.
PostPosted: Tue Aug 03, 2010 1:31 pm
Very simple. First remove the dash bezel.
hawkjet wrote:
First remove the fascia from around the instrument panel and radio.
There are two plastic rivets going up into the fascia above the instrument cluster. Press the center of the rivets upward (pics 1 & 2) and then carefully pry the rivets out (pic 3).
Pry the trim ring off the ignition switch (pic 4) notice I put electrical tape around the screwdriver blade to avoid marring the trim. Then pull out the 'cubby hole' on the left of the wheel (pic 5). Tilt the wheel all the way down and pull the panel off the dash (pic 6).
Reach behind the right side and disconnect the connector(pic7). Carefully tweek the panel to get it around the wheel and out of the way.
Then tilt the column all the way up, release the 5 clips that hold the cluster in place, angle the bottom of the cluster towards you to get it over the column, then tilt the cluster all the way down, and remove the cluster. You might be able to get by without moving the column, but its easier if you do.
The SLE cluster might work for you, but the SE or SSEi will not.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Tue Aug 03, 2010 1:40 pm
Online
Year and Trim: 2006 Cadillac STS-V, 2004 Pontiac GTO
On step 5, we have the HUD switches which removal would be similar, just that you'll need to disconnect the pigtail going to them.
PostPosted: Tue Aug 03, 2010 3:04 pm
Thanks guys!
Is there a special tool to push up the rivets cleanly? Or is it just a metal rod you used to push them up?
Sadly, no HUD here. Fully loaded with everything, except the HUD. :(
PostPosted: Tue Aug 03, 2010 3:12 pm
You can use anything, a ball point pen, etc...
-Andrew-
PostPosted: Tue Aug 03, 2010 3:43 pm
Anything will work on the pins.
I thought HUD became standard again on the GXP's? I know it was an option on the 03 SSEi. Interesting. All the GXP's I've ever seen have had HUD.
PostPosted: Tue Aug 03, 2010 5:05 pm
Online
No, now that he mentions it, I've seen a few on AutoTrader without HUD.
PostPosted: Tue Aug 03, 2010 7:55 pm
Anyone ever retrofit a HUD? Sure would be fun to have...
PostPosted: Tue Aug 03, 2010 9:54 pm
I think Andrew actually had a HUD for sale at one time, but I think you'd need to replace at least the upper dash panel. Not sure about the harness, either. Andrew?
BTW, I don't think HUD was ever standard equipment on any car. Just one of those subjective options, like a sunroof, heated seats and CDX/XM that can either keep the cost down or make it go up. They sure add to the experience, though. :)
2005 Bonneville GXP (SOLD), Crimson Red Tintcoat
Other Rides: 2009 Solstice GXP Coupe #606, Cool (Liquid Silver) | 2007 BMW 750Li, Toledo Blue Metallic
Past Rides: 2007 Grand Prix GXP, Red Jewel Tintcoat | 2004 Grand Prix GT2, Fusion Orange | 2002 Bonneville SSEi, Black | 1999 Regal GS, Black | 1997 Bonneville SSE, Blue-Green
1994 Cutlass Supreme S, Turquoise | 1989 Cutlass Supreme IS, Bright Red | 1988 GMC Sierra 1500, Dark Red | 1982 Regal Sport Coupe, Maroon/Silver | 1975 LeSabre, Beige
Wife's Chariot: 2006 Buick Rainier CXL, Red Jewel Tintcoat
PostPosted: Tue Aug 03, 2010 10:15 pm
GXPete, from 92-02 it was standard on SSEi's. That I know almost 100%.
PostPosted: Tue Aug 03, 2010 10:41 pm
I think 00Beast is correct, but I can't prove it except to go to Edmunds and use their appraise your car button. :)
Brad - 1/21/1977 .. 10/23/2013 ...... Aaron - 1977 .. 2017 ..... ....... B & B
PostPosted: Wed Aug 04, 2010 9:00 pm
Your are right, Ed. I just checked the '02 Bonne brochure book I still have from when I had the '02 SSEi and sure enough, HUD was standard. Forgot that.
PostPosted: Wed Aug 04, 2010 9:19 pm
GXPete wrote:
Your are right, Ed.
:banana: :banana: :banana: :beerchug:
That phrase never gets old, LOL.
PostPosted: Wed Aug 04, 2010 9:21 pm
GXPete wrote:
Your are right, Ed.
Just don't get to hear it very often, huh? :)
PostPosted: Wed Aug 04, 2010 9:25 pm
Pretty much. Sorry for dragging your thread wayyyy off topic, lol.
PostPosted: Wed Aug 04, 2010 9:28 pm
No worries. I think I asked the question about the HUD that started all of that... :)
PostPosted: Thu Aug 05, 2010 1:05 am
Did you get the instrument panel fixed? or did I miss that?
PostPosted: Thu Aug 05, 2010 1:06 am
Not yet. That will be happening next week.
PostPosted: Mon Jan 06, 2014 1:20 pm
Year and Trim: 2004 GXP
When removing the front fascia, were there any clips or did it just slip off after removing the front fascia screws/rivets, unplugging and the DIC control panel and disconnecting the HUD buttons? I just don't want to break any clips taking it out and then when putting it back in, it doesn't stay in place.
Thanks,
John
There are no new unread posts for this topic. Instrument cluster removal
CosmicVagabond
Sun Dec 16, 2012 10:46 pm
There are no new unread posts for this topic. Instrument Cluster and DIC buttons
WildGXP
Fri Nov 21, 2014 5:49 pm
WildGXP View the latest post
There are no new unread posts for this topic. Gremlins in my cluster.....
Bl4z3
Thu Jan 31, 2013 1:54 am
repinS View the latest post
There are no new unread posts for this topic. 2005 GXP Cluster Gone Wild
erichthecatt
Fri Sep 06, 2013 10:54 am
There are no new unread posts for this topic. Wiper arm removal
mark a. chew
Tue Sep 19, 2017 1:49 pm
