It is currently Wed Apr 25, 2018 4:36 am
 Post subject: Back 4 spark Plugs
PostPosted: Sun Aug 01, 2010 9:55 pm
Year and Trim: 1997 Bonneville SSE
2005 Bonneville GPX
Culd I get some insight on how to change the back four spark plugs on my GXP? I need all the help I can get. Thanks and take care. Jonathanb
 Post subject: Re: Back 4 spark Plugs
PostPosted: Sun Aug 01, 2010 10:47 pm
2005 Bonneville GPX
I could use any tips and information inhh order to make this process pain free. Any advice would be greatly appriciate it. Take care.
PostPosted: Sun Aug 01, 2010 10:56 pm
Year and Trim: before cars
Have an assortment of metric tools and take your time. Keep removing bolts until the spark plugs come out.
PostPosted: Mon Aug 02, 2010 9:43 am
Year and Trim: 2006 Cadillac STS-V, 2004 Pontiac GTO
1) Remove strut tower brace
2) Remove Secondary A.I.R. shut off valve. This is the big piece in the center of the rear cam cover. You'll need a long extension with either a swivel or U-joint and a 10mm socket to get the nuts off the exhaust flange. From there, the same 10mm works on the bolts that hold it to the cam cover. You will need a 10mm wrench on the one bolt a socket can't get to. Disconnect A.I.R. feed from the pump (the big rubber hose).
Have at it... They replace the same as the front.
This is what I sent to you via PM. I thought you got it;
Quote:
NP. It's the same as the front, except you need to remove the Secondary A.I.R. shut-off valve that sits right in the center, on top of the cam cover. And before that, I would remove the Strut tower brace. I believe that's a 13mm bolt. They're a threaded nut, so don't worry about having issue putting it back in.
You're gonna need some extensions, and a swivel or u-joint, with a 10mm deep well socket. This will be used to undue the nuts on the exhaust flange for that the Secondary A.I.R. system feed into. From there, a combination of a 10mm wrench and 10mm socket will undue the bolts holding it to the cam cover. Disconnect the electrical harness, as well as the feed tube from the Secondary A.I.R. pump.
With this, you can take it all off, put it aside, and you're free as you are in the front (sans a little tighter workspace.
PostPosted: Fri Sep 03, 2010 9:43 pm
2005 Bonneville GPX
Hi guys, it was painless. All I had to do is remove the bar running horizontally over the engine, then I removed the peice of equipment above the rear plugs. I used a swivel ratchet that hooks on to the ratchet and I also used a spark plug swivel ratchet and it angled down into spark plug hole perfect. It took me about 45 minutes to do all 8 plugs. Pretty painless, the fear of the unknown got to me but once I got my hands dirty it was a piece of cake. If you have any questions about it PM me and I can sure help you out. Take care guys and girls
There are no new unread posts for this topic. Spark Plugs
dpnewfie
Tue May 26, 2009 12:33 am
There are no new unread posts for this topic. Im getting nervous about spark plugs
zigger21
11
2495
Tue Aug 24, 2010 11:53 am
bonneville dan-o View the latest post
There are no new unread posts for this topic. Replacing rear spark plugs.
Bill's GXP
Fri Aug 23, 2013 7:21 pm
Nezzies 2005 GXP View the latest post
There are no new unread posts for this topic. Spark plugs and wires on a mid to late nineties Caddy
laxmangl
Sun Nov 01, 2009 4:21 pm
alec_b View the latest post
There are no new unread posts for this topic. Spark plug change on Northstar
GXPMan243
Thu Mar 23, 2017 10:38 pm
mark a. chew View the latest post
