It is currently Fri Feb 14, 2025 11:33 am
Post new topic Reply to topic  [ 7 posts ]
PostPosted: Mon Mar 03, 2014 2:32 pm
Year and Trim: 2005 Pontiac Bonneville SE
Looking for any advice on replacing the factory stereo with aftermarket. I do not have the Monsoon system. Just planning on a decent aftermarket stereo, keep factory mids and highs and adding an amp and subwoofer. Car is for my mother in law and she likes to jam the tunes some. LOL Want to keep costs down to a min, so do I HAVE to buy any special wiring harnesses, or can I just tap into factory, solder some connections and be good to go?? I was on Crutchfield and they stated I would need "Axxess GMOS-05 Factory Integration Adapter". I know I need an antenna adapter and of course face plate adapter. Just wanted to know if there was a way around the Axxess adapter. Just trying to keep install as easy and cost effective as possible. I may replace rear deck speaker's and keep the fronts stock. Thanks for any advice.
Keith
PostPosted: Mon Mar 03, 2014 4:24 pm
Year and Trim: 2006 Saab 9-3 SportCombi
You'll need to buy an adapter because you have a factory ribbon wiring harness. Regardless if you had a standard set of wires, a $10-15 harness is recommended because you never know if you'll replace the radio in the future due to it malfunctioning. Ask me how I know, it is a PITA to wire a radio when you can't take the wires on to a work bench and do it in front of you.
-Mike
-17x8 OZ Racing Superleggera wheels- -GReddy Exhaust- -K&N Panel filter- Tinted Windows- -Blacked out side markers-
Tune coming soon
2000 Bonneville SLE - Totalled
PostPosted: Mon Mar 03, 2014 11:20 pm
Year and Trim: 1988 LE
2000 SSEi
The warning chimes are played through the door speakers. To keep them you need the GMOS-05 for your non amplified system, however it you are fine with losing them you could get the GMOS-07 i believe (not 100% sure but it has the same dock and lock connector). You will also likely have to trim out the back of the dash slot because the average radio has more depth than the stock one. Its not too hard really just use a dremel and go slow and you won't cut the ribbon cable. Also RCA's for the sub will go along the left side under the carpet quite well.
-Austin-
yourgrandma wrote:
And thats how I got my mom pregnant.
PostPosted: Tue Mar 04, 2014 12:54 am
2004 Bonneville GXP
The GMOS-05 keeps the door chimes and OnStar if your car is so equipped. If you can do without these there are cheap dock and lock adaptors that connect the factory harness (it is not a ribbon cable on 2005) to the radio for under $20.
bobgto65
PostPosted: Tue Mar 04, 2014 10:28 am
Thanks for the advice guys. Not really too worried about door chimes, so looks like I will be saving a little $$$ on the install. Car is for my mother-in-law anyhow. LOL :banana:
PostPosted: Wed Apr 30, 2014 4:34 pm
You will be cutting plastic with an aftermarket radio. Don't know why Pontiac designed them so shallow.
PostPosted: Wed Apr 30, 2014 6:40 pm
They weren't thinking about the HU being replaced 15 years down the line.
There are no new unread posts for this topic. 2005 SE radio
1oldman
Mon May 30, 2016 12:20 am
samples08 View the latest post
There are no new unread posts for this topic. Replacing stock radio with a radio from a newer Bonneville
SuperHbody
Sun Dec 22, 2013 12:43 am
human View the latest post
There are no new unread posts for this topic. Replacement radio.
rustyroger
Mon Jul 14, 2014 2:39 am
rustyroger View the latest post
There are no new unread posts for this topic. Alpine IVA-W203, getting it to fit in a 2005 radio slot Help
zigger21
Sun Sep 12, 2010 10:25 pm
willwren View the latest post
There are no new unread posts for this topic. 03 Bonneville SLE Radio help
Anonymous User
Mon Mar 28, 2011 5:37 am
Anonymous User View the latest post
Users browsing this forum: No registered users and 3 guests
