It is currently Fri Apr 25, 2025 6:52 pm
Post new topic Reply to topic  [ 5 posts ]
PostPosted: Mon Mar 10, 2014 6:55 pm
Year and Trim: 2001 SSEi
Is there anything difficult about installing the Aeroforce Interceptor and hooking it up? If I got a second one, would I need to get a splitter or anything to make it work?
Black 2001 SSEi | Performance: INTENSE FWI, INTENSE Shift Kit, INTENSE 180* Thermostat, GXP Calipers (custom powder coated), EBC GD Sport Drilled and Slotted Rotors, EBC Redstuff Brake Pads Aesthetic: Debadged | Cleared Front and Rear Corners | Red Rear Turn Signals | Bright White LED Reverse Lights | Black Centerpiece | Black Pontiac Emblem | 35% Huper Optik Tint | GXP Interior (Carbon Fiber Vents and Handle Inserts, Stainless Handles, Shifter, Black Buttons for Windows and Cockpit, Cupholders) | Hood and Rear Quarterpanel Herpes :thumbdown:
PostPosted: Mon Mar 10, 2014 7:35 pm
Depending on which model of Interceptor you get. Older ones may need a 12v power source. Newer ones feed power directly from the OBDII port.
Don't really see the need for two unless you are highly modified.
PostPosted: Mon Mar 10, 2014 8:47 pm
Thanks nos. Always a big help! I ordered it a few minutes ago right off of the INTENSE website so I assume it's new. So it plugs right into the OBDII port underneath my knees? If I had 2, I'm guessing I'd need a splitter?
PostPosted: Mon Mar 10, 2014 8:56 pm
You don't need 2. Put that money towards other mods, lol.
PostPosted: Mon Mar 10, 2014 9:06 pm
:withstupid:
Yes. You just plug it in into the port and it'll run when you start the car and turn off a couple of seconds after you turn off the engine. I can't say for sure on the splitter. I think you can only get that if you buy them paired together straight from Aeroforce.
There are no new unread posts for this topic. installing aeroforce
xyeLz
Mon Mar 24, 2014 1:52 pm
bs009 View the latest post
There are no new unread posts for this topic. 3X Aeroforce
2003 SSEi
Wed Oct 29, 2008 10:05 am
2003 SSEi View the latest post
There are no new unread posts for this topic. aeroforce question
bonnevillain
Wed Oct 15, 2008 6:49 am
gonzo4191 View the latest post
There are no new unread posts for this topic. 12v acc line for aeroforce install
bonnevillain
16
2042
Wed Oct 22, 2008 7:17 pm
bonnevillain View the latest post
There are no new unread posts for this topic. Aeroforce scan guage install
Pontiacdad
Fri May 23, 2008 1:23 am
laxmangl View the latest post
Users browsing this forum: No registered users and 2 guests
