It is currently Tue Mar 19, 2019 2:51 pm
Post new topic Reply to topic  [ 12 posts ]
 Post subject: Dual Mode Mufflers?
PostPosted: Mon Oct 22, 2018 4:38 pm
Year and Trim: 2000 SSEI
What do you guys think, I came across a set of Camaro ZL1 Dual mode mufflers and thinking about trying them in place of my stock mufflers (installing Dual mode switch) If you flip them opposite sides the line up a little bit like stock... Obviously they will need to be modified a little to work.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
 Post subject: Re: Dual Mode Mufflers?
PostPosted: Mon Oct 22, 2018 4:55 pm
1994 Buick Regal Custom
I have only seen others use cutouts connected up near the downpipe for all of their exhaust switching needs.
I am also concerned with the end result, as ultimately the soundtrack will be much different than that of a dual exhaust LS V8 (the term barfing giraffe comes to mind), and it is often an uphill battle to get something that sounds anywhere near palatable.
Guess what I am concerned about, is that even if you invested all of the effort to get it working, you would hit it and be disappointed with the results.
~Randall~
PostPosted: Mon Oct 22, 2018 5:05 pm
lol if it doesn't sound good i will put the stock ones back on and toss these.. Mostly bored. Thought it might be a interesting way to kill some time.
Shane "RedZMonte"
PostPosted: Mon Oct 22, 2018 6:20 pm
Am I seeing this right? Are those vacuum driven actuators?
~Randall~
PostPosted: Mon Oct 22, 2018 9:47 pm
A lot of dual mode exhausts are vacuum powered.
If the rest of your exhaust is stock, I don't anticipate the car getting too much louder with the baffles open. The stock resonator and cat on a 2000+ quiet it down most of the way.
"Penelope" - 2003 SLE - 187k Miles
"Sydney" - 2000 Honda S2000 - 61k miles
PostPosted: Tue Oct 23, 2018 2:49 pm
They are Vac operated. Which is easy enough, the corvette companies have a vac switch for the C6 to add the vac operation on a car without the dual mode system that can be used or you can make one for like $20 with some vac line and a Solenoid. I can replace or remove the Resonator if it is too quiet. Those mufflers are surprisingly heavy.
On a side note, We have a 08 DTS at work and the exhaust is basically the same but it has a larger mid pipe/Y pipe and resonator... It looks to be same specs as the later (03+ iirc) SSEI's.. Might have to see if i can find a used midpipe/Y pipe locally and swap.
pretty close in shape in orientation...
S
Shane "RedZMonte"
PostPosted: Thu Oct 25, 2018 4:05 pm
Getting installed next Wed. I will get Video of before and after.
Shane "RedZMonte"
PostPosted: Mon Oct 29, 2018 11:41 am
If they are truly vacuum actuated, and there is no electrics going to them, you should be ok. I know the latest bi-modes (like used on the SS), can be controlled through the infotainment system IIRC, which means there is electronics running it. So those one would want to steer away from.
Those might actually sound ok since the mufflers are so small. There isn't a lot there to absorb sound to begin with. :)
Daily Drivers:
2015 Chrysler Town & Country Limited Platinum: Mommy's NEW RGC
2007 Chrysler Town & Country Limited: Daddy's beater affectionately called the Rolling Garbage Can or "RGC" for short
2009 Chevrolet Impala SS: LS4 V8, Victory Red
1999 Chevrolet Suburban: Sunset Gold Metallic - Daddy's winter beater and plow truck
PostPosted: Tue Oct 30, 2018 1:43 pm
I might do a electronic vac switch Like the "NPP IN A BOX" or make my own (Simple to install) not sure yet. I guess i could use a vac system that will close under Vac and open under boost...
https://www.southerncarparts.com/corvet ... gLDS_D_BwE
S
Shane "RedZMonte"
PostPosted: Wed Oct 31, 2018 7:21 pm
They are installed without the vac.. Sounds good. Deep and mellow, not to loud and quiet on the highway. Dual 2" stainless Y into 2.25" Vbands on the mufflers.
Shane "RedZMonte"
PostPosted: Thu Nov 01, 2018 3:51 pm
I cant get the videos to upload... Posted on Facebook let me know if this link works for you.. https://www.facebook.com/groups/2149575 ... et&fref=nf
S
Shane "RedZMonte"
PostPosted: Thu Nov 01, 2018 8:23 pm
The links works. Have to scroll down to the 2nd post, but still......
She sounds good. A bit louder than normal.
'02 Pontiac Bonneville SE 106k miles, N/A, SSEi exhaust system, boat roller mount.
(yes, there is a story behind my avatar.)
There are no new unread posts for this topic. How to get dual mufflers on bonneville SE?
Dannyg420
Thu Oct 17, 2013 6:16 pm
Bonnie01 View the latest post
There are no new unread posts for this topic. dual exhaust and mufflers
psburtis
11
3770
Mon May 26, 2008 9:21 pm
Bugsi View the latest post
There are no new unread posts for this topic. CAI and Mufflers?
WS-13
17
2504
Tue Jan 19, 2010 6:45 pm
01bonneSC View the latest post
There are no new unread posts for this topic. slp mufflers
jtate300
Wed May 05, 2010 3:15 pm
J Wikoff View the latest post
There are no new unread posts for this topic. no mufflers? yes or no?
Dannyg420
18
1245
Thu Jul 25, 2013 11:36 pm
Users browsing this forum: No registered users and 6 guests
