I have a spare set of head lights (cracked and chipped), that I am working on a how-to for fixing siezed adjuster screws.
I've noticed that the 9007 dual filament are axial, just like the 9006 low beam. The difference is the low beam is off-center from the axis.
The theory is that I can use the 9007 dual filament, positioned so that the low beam matches the housings optics with the high beam clocked to increase my high-beam light output (similar to the quad highs that were on the LeSabre). With the high beam clocked, I can direct more light to the sides of the road.
I will be testing this in the spare headlight assemblies first, but was curious if anybody else had done something similar?
Headlights
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Headlights
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- MattStrike
'04 Dirtymax
'97 Camaro
Re: Headlights
More questions...
How does the lamp monitor work? I want to install a relay harness on the SSEi, and something tells me I'll lose the function of the lamp monitor.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Re: Headlights
Yep, you'll lose that with a relay harness. IIRC there's some form of emulator or something for them, though...
