I currently have an L67 from a 1998 Bonneville with 240,000km and blown head gasket. I've never heard it run, but I plan to rebuild, hone and add some performance while I'm in there. What I am aiming for is a fast, reliable vehicle. Which brings us to my first question, how fast is un-reliable? I am hoping to make around 300whp.
I've done a lot of reading already, and with that figure in mind, I'd would need:
-S1X package(heard nothing but good things)
-larger injectors
-fuel pump wiring kit(larger fuel pump?)
-header of some sort, does anyone know if the ZZP SS headers fit the bonneville?
-N* throttle body
-3.4? MPS pulley
-and all the bearings, gaskets...
Does anyone see anything that I am missing? or should be doing differently?
I'll will be deleting the A/C, is a delelte pulley really necessary? do they not make a belt that just goes straight to the alt? Or is the motor mount in the way?
EGR and charcol canister will be deleted, unless these affect the engine negatively.
So far, I've only managed to pull the engine, subframe, fuel pump/sender and the wiring harness.
Here are some pictures from a few days ago:
The wiring harness, which reminds me, if you couldnt tell we're scrapping the car and the engine is going into:
And the builder:
After we pulled out the engine, Eric pull out the tequilla... lets just say its a good thing the car wasnt moving
