1991 Buick Regal hard shifts
Merrillspontiac
- Posts like an LN3
- Year and Trim: 2000 Pontiac Bonneville SE
I just got my 91 back on the road after sitting all winter, and ive noticed a few issues, with it. after it sits overnight, it cranks for about 5 seconds before it starts. The transmission seems to shift hard from 1-2 then 2-3 under normal acceleration all the time, I also noticed that it stumbles if Im cruising anywhere from 50-60 MPH when I gently try to accelerate, but if I accelerate harder, it downshifts and accelerates just fine, trans fluid, filter plugs, wires and FPR are new as is the trans modulator I did do the seafoam treatment before changing the fluid and filter, there was no metal in the pan and the fluid looked good. could the TPS be faulty?
Last edited by Merrillspontiac on Tue Mar 09, 2010 11:28 pm, edited 3 times in total.
1993 Buick Regal GS Coupe
- Year and Trim: .
Re: 1991 Buick Regal hard shifts
How new is the transmission modulator? Check the vacuum line to it for cracks or leaks. Does it slam into reverse also? Is it an adjustable modulator.
Check all the vacuum lines by spraying them with carb cleaner. If the idle increases, then there is a leak where you sprayed it.
If you can, take a picture of the modulator.
Merrillspontiac
- Posts like an LN3
the modulator is brand new from advance, it is adjustable, it shifted hard before I changed the modulator as well, it shifts smoothly into reverse and drive, the vacuum lines were also replaced as well. it also seems like when im slowing down and it gets to 17mph, it downshifts a little hard too.
- Year and Trim: .
You need to check the TPS and the adjustment on the TV cable. Have you checked the coils?
Last edited by myfirstbonnie on Tue Mar 09, 2010 11:22 pm, edited 1 time in total.
Merrillspontiac
- Posts like an LN3
I readjusted the TV cable and it shifts the same. so its most likely a bad coil or TPS?
Merrillspontiac
- Posts like an LN3
- Year and Trim: .
If you have a meter, they can be checked easily. Do you have an SES light on?
Merrillspontiac
- Posts like an LN3
no SES lite, yes I do have a meter, what is the proper procedure?
Merrillspontiac
- Posts like an LN3
- Year and Trim: .
Merrillspontiac
- Posts like an LN3
I forgot to mention that when I slam the hood when the engine is running and its cold, it will stall out.
- Year and Trim: .
Unplug the MAF while it is running and see if it idles different, dies, or no change.
Merrillspontiac
- Posts like an LN3
started up the car and unpluged the maf, the ses lite came on, plugged it back in the engine stumbled and died, disconnected it again, restarted it slammed the hood 3 times no stall, plugged it back in stumbled for a second than went back to normal idle abnd ses lite went out, slammed the hood and it stalled out.
Merrillspontiac
- Posts like an LN3
Im thinking that I have an issue with the MAF
- Year and Trim: .
Check your TPS and coils first. The MAF is quite expensive. Have you taken the intake tube off and checked to make sure some critters haven't made a home in there? Get a can of MAF cleaner and remove it and spray it real good. Some people have even used a q-tip to clean the filaments, but I usually just spray them real good. Just don't use anything but MAF cleaner on it.
Merrillspontiac
- Posts like an LN3
can I use coils from a series II or series III?
- RJolly87
Usually the official test for a MAF sensor, is to tap the black box of the sensor with the handle of a screwdriver, and if it is bad, the car will react to it.
Merrillspontiac
- Posts like an LN3
does it matter if it is warm or cold?
94SilverSSEi
68 w/400
Just a thought but couldnt u check the MAF by taking it out of the 92 and putting in in the 91 and see if there is any change that way you can rule out MAF
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
Merrillspontiac
- Posts like an LN3
swapped MAF and TPS with my 92, no change, tomorrow I will swap coils and see if anything changes.
