It is currently Wed Apr 25, 2018 4:34 am
PostPosted: Wed Apr 08, 2009 11:55 am
Year and Trim: 1997 Pontiac Bonneville SE (H4U)
Alright guys, I've been dormant for a while thanks to school. But school is almost over for the semester, and my girlfriend's father is in a pickle. The TCC switch on his 99 montana is apparently faulty. I understand that these are 4t65e transmissions, and the TCC switch is located in the valve body. Anyone have access to alldata or similar to grab the procedure for replacement? I'm betting the transmission needs to be either removed or *dang* near close to it to finish this job. From sporadic internet searching, I almost understand that there's a cover on the drivers side of the trans that needs to be removed, which probably means everything needs removed.
- Josh
1994 Bonneville SSEi - 136k mi - FWI, 180* T-stat, Fresh upper gaskets
1997 Bonneville SE - 110k mi - H4U, 3.06:1, Tinted Tails, Bridgestone Potenza G009 225/60/16s
Performance: INTENSE PCM, INTENSE 180* T-stat, Gutted air box, K&N air filter, Ported LIM, Borg Warner Wires, NGK TR-55 Plugs, Adjustable Trans Modulator.
Bells and Whistles: Flowmaster 80 crossflow muffler w/ quad tips, 2x Kicker CVR12 Subs in vented box, 1000W RMS 1-ohm American Bass Amp, Alpine MRP-F200 4-channel amp (temporary), Infinity 60.7CS 6.5" Component System (front), Blaupunkt 3-way 6x9s (rear), Pioneer DEH-P6900UB Head Unit, Hardwired Whistler Pro 58 Radar Detector, Hardwired Navigon 2100 GPS
PostPosted: Wed Apr 08, 2009 12:37 pm
Take a look through this thread: viewtopic.php?f=9&t=5832&hilit=since+everyone&start=60
You have to drop the subframe enough to get the sidecover off.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Wed Apr 08, 2009 1:04 pm
That helps. In the valve body picture, ordered from top to bottom, is the TCC solenoid number 1, 2, or 3 down?
- Josh
PostPosted: Wed Apr 08, 2009 1:08 pm
Shift solenoids use the yellow connectors, pressure control solenoid uses the gray connector, and TCC solenoid uses the blue connector.
-Andrew-
PostPosted: Sun May 03, 2009 6:01 pm
Update - I drove the van. No overdrive, and once in a while if you take your foot off the gas, and reapply throttle, it will clunk which indicates that perhaps the torque converter is not unlocking at some points. He gets code number P0742 (TCC Stuck On/Fail TCC Solenoid). We don't want to rip this apart until we're certain on what it is in the case that we have to order parts. Why would P0742 throw overdrive/4th out of commission? I was cruisin @ 55 MPH @ 2500 RPM and no shift. Does it see the P0742 (code was active when driving, takes 20-30 mile drive to active) and disable overdrive?
- Josh
There are no new unread posts for this topic. 2001 Pontiac Montana question
Baileyjack
Wed Jul 02, 2008 6:21 pm
Baileyjack View the latest post
There are no new unread posts for this topic. Broken wheel stud on '04 Pontiac Montana: OMG!!!
Ken_W
16
5387
Wed Aug 18, 2010 11:02 pm
There are no new unread posts for this topic. 1999 Pontiac grand am E-brake
smokingfireball
Sun Sep 04, 2011 10:30 am
There are no new unread posts for this topic. Project Montana?
CMNTMXR57
53
2445
Tue Dec 18, 2012 4:53 pm
There are no new unread posts for this topic. How to relieve fuel pressure on 2004 Montana?
Ken_W
Sun Sep 19, 2010 10:04 pm
