It is currently Fri Apr 26, 2019 10:16 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: cat delete?
PostPosted: Tue Dec 30, 2008 4:27 pm
Year and Trim: 1994 SSEi 1999 SLE
Awesome. Good luck!
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
PostPosted: Tue Dec 30, 2008 4:53 pm
Year and Trim: 2000 ssei
i have made an exhaust list for when i get my highflow cat this is what i am thinking about saving my money for over the next few months
Muffler, Red Hots, 2 1/2 in. Inlet/2 1/2 in. Outlet, Red Steel, Each <------1 this will be an experiment to replace the resonator if i don't like it i am only out $12.00
$11.95
Muffler, Aero Chamber, 2 in. Inlet/2 in. Outlet, Steel, Aluminized, Black, Each <------2
$67.95
Catalytic Converter, Stainless Steel, Universal, 2.5 in. Inlet/Outlet, 16 in. Length, Each <------1
$72.95
total cost before tax and shipping $220.80 i also have a $20 off coupon that i am not counting
also if i decide to get a 3" downpipe later on how does it attach to the 2.5" converter?
2000 ssei white debadged, autozone solid front mount, NGK tr55 plugs, Napa Beldin wires, MSD Coils, drilled slotted rotors, monroe max air rear shocks, 18" KMC Hot wheels redline w/ 235/50/18 bfg G-force tires, pioneer DEH-P580mp deck, Infinity Ref 6.5s and 5.25s, Kappa 6x9's on crossfire amp, kappa 12 on kenwood amp, and cleared headlights.
Gumball wrote:
my pockets dont sag and are still kinda tight.
:banana: Oh, you've got a ricer muffler! I've always wanted to try that to replace a resonator.
PostPosted: Tue Dec 30, 2008 4:55 pm
what the flowtech or the hookers?
PostPosted: Tue Dec 30, 2008 5:00 pm
I meant the "Red Hots" muffler you listed.
Also, I think you'd be better off with a 3" in/out cat. If you'd still rather use a 3" downpipe to a 2.5" cat, it's still the same coupler that an exhaust shop would use to go from a 3" pipe to a 2.5". It's a conical type adapter. I've seen it on other cars, and it's barely noticeable since it just goes in a quarter of an inch all the way around.
PostPosted: Tue Dec 30, 2008 5:05 pm
yeah sorry i forgot it doesn't say flowtech redhots, i figure a glass pack up there will make for a nice idle sound without droning on.
so whichever way i go with the cat it can be installed without problems thats good to know
PostPosted: Tue Dec 30, 2008 9:24 pm
I found that deleting the resonator was a bad idea so I installed a 36" long x 3" resonator like this.
You are supercharged so I would recommend going to a 3" Cat and resonator. The Y should be a Flowmaster 3" to twin 2 1/2". :wink:
PostPosted: Tue Dec 30, 2008 9:48 pm
your exhaust is beautiful!!!!
was the reason for not changing the resonator performance or sound
PostPosted: Tue Dec 30, 2008 10:00 pm
Sound. With a resonator, it's all about toning it down and managing the drone.
PostPosted: Tue Dec 30, 2008 10:03 pm
ok...i want to test the glass pack when i get it cuz it's not expensive also i have a friend who is a welder so its not too big deal
PostPosted: Tue Dec 30, 2008 10:51 pm
That's great.
Experimentation leads to innovation. :banana:
Be sure to post before and after sound clips. :wink:
PostPosted: Tue Dec 30, 2008 11:05 pm
yep now i just need money!!!!
PostPosted: Wed Dec 31, 2008 6:48 am
Year and Trim: ....
You could just straight pipe it, that gives it a nice sound! :twisted:
PostPosted: Wed Dec 31, 2008 9:10 am
yeah but this is my dd and i use it for marketing at work (which i hate doing) straight pipes end to be unpolite
PostPosted: Wed Dec 31, 2008 11:18 am
Remember that 3" exhaust is far too much for your car. The Bullet is pretty extensively modded.
Open up too much and you'll lose low-end torque.
PostPosted: Wed Dec 31, 2008 2:27 pm
yeah i'm gonna leave the stock size for now
There are no new unread posts for this topic. EGR Delete
99ssei
15
9492
Sun Oct 12, 2008 5:07 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Benefits of an EGR Delete?
stephenssei
Thu Apr 13, 2017 11:46 am
Wes View the latest post
There are no new unread posts for this topic. Any tangible value to A/C delete?
Bugsi
Fri Sep 23, 2011 9:59 am
There are no new unread posts for this topic. (Accidental) EGR delete
The Crunge II
Wed Nov 26, 2008 1:38 am
PDXGTP View the latest post
There are no new unread posts for this topic. Intense or ZZP PCM? And what codes to delete?
comatoast
76
6430
Sun Oct 24, 2010 11:14 pm
comatoast View the latest post
