It is currently Wed May 21, 2025 8:10 pm
PostPosted: Thu Jan 09, 2025 5:09 am
Year and Trim: 2000 Pontiac Bonneville SLE Tan on Gold Metallic
I'm really bad at doing things practically, and I want heated seats. I dont currently have heated seats. I know there are heated seat covers, but i already have seat covers that I use, and if I added another seat cover on top of that I would feel awkward about it. So I wanted to know how much it would take to do a full seat swap. Fuses, buttons, wires, seats, what all I need to do.
2000 Pontiac Bonneville SE, Tan on Gold Metallic, 160k miles. Aluminum wheels, vinyl wrap, aftermarket suspension and brakes, full fluid flush and sensor replacement @ 160k. 90% taillight tint, full SSEi sound system swap w/ Pio amp, embroidered floor mats and wooden bead seat covers (for class)
PostPosted: Thu Jan 09, 2025 11:19 am
I did this mod 15 years ago. To do it using OEM switches and seats, you need to have a very good understanding of how to read schematics as you will be adding a lot of wiring. I've attached a good starting point.
If you don't have that knowledge, then they make aftermarket pads that you can put under your seat covers that would be as simple as adding power and ground.
Right Heated Seat.pdf [134.22 KiB]
Downloaded 32 times
Left Heated Seat.pdf [115.23 KiB]
Downloaded 30 times
Heated Seats Schematic.pdf [82.49 KiB]
Downloaded 31 times
PostPosted: Fri Jan 10, 2025 12:25 am
Oh, sweet! Thanks a bunch. I will actually be seeing you this summer, would you be willing to work on my car to install these, or do you not do that type of stuff?
PostPosted: Fri Jan 10, 2025 10:11 am
Yes I do this type of stuff. Keep in mind this would be very laborious and would be a completely custom job.
There are no new unread posts for this topic. Full header vs powerlog
jdecker
Sat Nov 19, 2016 1:39 pm
haro1225 View the latest post
There are no new unread posts for this topic. Eaton gen 5 plus full height intercooler
Speedster400
Fri Jun 05, 2015 4:40 pm
There are no new unread posts for this topic. Heated windshield washer fluid
1fatcat
Tue Jan 11, 2011 5:04 pm
There are no new unread posts for this topic. Need help about swap L27
Bit
Mon Sep 29, 2008 2:29 am
Bit View the latest post
There are no new unread posts for this topic. top end swap on a l36
95se
Sun May 26, 2013 5:01 am
95naSTA View the latest post
