It is currently Wed Oct 05, 2022 4:20 am
 Post subject: 2003 SSEi Brakes
PostPosted: Sat Aug 28, 2021 3:14 am
Year and Trim: 2003 Bonneville SSEi.
:dontknow: I hear a popping sound when I press the pedal hard on the drivers side and sometimes the passenger. I don’t know if it’s the calipers or what. Happens driving forward only. I have just about FKN had it with this car. And the fact I have anxiety doesn’t help either. :banghead: :banghead:
 Post subject: Re: 2003 SSEi Brakes
PostPosted: Sat Aug 28, 2021 8:58 am
It could be either the strut top mount or something else in your suspension since braking will load it differently.
Have you put the front on jack stands and checked for play in the wheels? That will at least tell you if you have a control arm, tie rod or ball joint issue.
PostPosted: Sat Aug 28, 2021 12:50 pm
New outer tie rods. New control arms. It was aligned. Thinking caliper piston or the mount for the caliper. And it only happens when the brakes are under load and sometime when the front end squats down from that.
Short of that if I don’t find out the problem, likely to douse the thing with fuel and watch it burn. Have JUST …. HAD …. IT [-( :banghead:
PostPosted: Sat Aug 28, 2021 5:57 pm
It's an almost 20 year old car with cheaper maintenance cost than most it's age and price point.
It sounds like you're convinced it's the brakes, so pull the wheels inspect and check the torque.
PostPosted: Sat Aug 28, 2021 6:02 pm
Convinced….!? I feel it in the pedal sometimes.
PostPosted: Sat Aug 28, 2021 6:24 pm
Fixated, convinced, however you would like to categorize it.
It could very well be the brakes. But, since you presumably asked by starting a thread, I just gave you more things to look at in case it's not. The strut top mount is mechanically connected to the front brakes and is a common failure. The brake pedal can pick up on various body vibes and mechanical issues.
PostPosted: Sun Aug 29, 2021 10:47 am
Popping from in front can be any number of things, you have to lift it up and start checking what has a play or looks damaged/worn.
Strut mounts make a resounding pop with turning the steering wheel and with bumps and load changes. Even subframe bushings can cause this.
In my case, I didn't torque down my control arms enough and got popping. They can be a little tricky to torque down while on the ground.
"Penelope" - 2003 SLE - 232k Miles
"Sydney" - 2000 Honda S2000 - 90k miles
PostPosted: Thu Sep 02, 2021 2:40 pm
Was frustrated over a small thing. Left control arm - forgot to fully tighten the bolt. Now I’ll check the passenger side to see if they’re tight.
There are no new unread posts for this topic. 2003 SSEi looking for more POWAAAA
Skarddd
Mon Jan 13, 2014 1:40 am
There are no new unread posts for this topic. Mystery shutdown 2003 SSEi
rynmcdonald
Mon Nov 02, 2020 10:56 pm
rynmcdonald View the latest post
There are no new unread posts for this topic. 2003 SSEi SC pulley size
rynmcdonald
Sat May 21, 2022 7:31 am
There are no new unread posts for this topic. 2003 SSEi transmission question
rynmcdonald
Tue Aug 02, 2022 7:05 pm
There are no new unread posts for this topic. 2003 SSEi - Sunroof drain tubes
rynmcdonald
Mon Jul 12, 2021 12:32 am
