It is currently Wed Sep 28, 2022 7:19 pm
 Post subject: Park Ave rotors question
PostPosted: Thu May 20, 2021 4:00 pm
Year and Trim: 2003 Bonneville SSEi.
Are they larger all the way around or just on the front?
Looking to upgrade to the larger rotors soon and if they are bigger all around, may as well do all of them.
If post is in wrong section, my apologies.
PostPosted: Fri May 21, 2021 8:34 am
I would imagine the Park Avenue has the same brake rotor size as an SLE or SSEi 2000+ Bonneville.
If you want bigger rotors, GXP brakes bolt up, and the 4th gen F body set up is another upgrade. You would need to get the calipers as well.
"Penelope" - 2003 SLE - 232k Miles
"Sydney" - 2000 Honda S2000 - 90k miles
PostPosted: Sat May 22, 2021 7:24 am
Year and Trim: 1987 Oldsmobile Delta 88
1989 Buick Le Sabre
I had a quick check on RockAuto, seems the 1998 Park avenue and 2001 Bonneville rotors have the same part numbers. Which makes sense, GM would want common parts for similar cars simply to reduce production logistics issues.
Roger.
There are no new unread posts for this topic. Rotors and pads
Allmachtige
31
3038
Wed Apr 29, 2009 2:10 pm
BonneMe View the latest post
There are no new unread posts for this topic. Brake Rotors
ddalder
Tue Jan 26, 2016 11:52 am
There are no new unread posts for this topic. Front slotted rotors only?
samples08
Mon Dec 14, 2015 1:11 am
Arrowhead View the latest post
There are no new unread posts for this topic. Bang for your buck ROTORS!!!!!!
jmal843
Tue Mar 15, 2011 3:29 am
There are no new unread posts for this topic. Brakemotive drilled and slotted rotors
nishnobguad
Mon Apr 15, 2013 7:55 pm
mylittleblackbird View the latest post
