It is currently Mon Mar 08, 2021 4:59 am
PostPosted: Thu Nov 12, 2020 4:22 pm
Year and Trim: 2005 SE
My '05 Bonneville needs tires. Looks like I might be able to use a set of wheels I have from my 1996 Z51 Corvette, they will require adaptors. The Vette wheels and tires are 17X9.5 with 51mm backspace and 275/40-17's. For some reason, that size tire is available cheap. The outside diameter is within 5mm. Has anyone ever tried this? Thanks, Ken
Chance favors the prepared mind {Louis Pasteur}
PostPosted: Fri Nov 13, 2020 9:34 am
The factory wheel on an SE is a 16X7 I think with a really high offset. You will most likely rub with those wheels rather intensely. lol If you do put them on though, definitely post a photo!
"Penelope" - 2003 SLE - 218k Miles
"Sydney" - 2000 Honda S2000 - 81k miles
PostPosted: Sat Nov 14, 2020 9:50 pm
The bolt pattern is different too.
Bonneville = 115mm
Corvette = 120.7mm
PostPosted: Sun Nov 15, 2020 12:55 am
https://www.willtheyfit.com/index.php?w ... offset2=51
Looks like you would have to have the wheels redrilled since I doubt there's enough room for adapters. This would probably offset the price difference in tires. That's provided there's room for 275s all the way around. It's also a 40mm difference in diameter.
There are no new unread posts for this topic. Brake Upgrade info... F-body Corvette
redzmonte
Thu Oct 03, 2013 11:57 am
731Loadmaster View the latest post
There are no new unread posts for this topic. L32 bonneville
Bonneville'n
Sun Jan 26, 2014 6:50 pm
Bonneville'n View the latest post
There are no new unread posts for this topic. V8 in my 96 bonneville sse
theirongiant99
Fri Jun 16, 2017 2:51 pm
There are no new unread posts for this topic. 03 Bonneville SE mod help?
Dannyg420
Wed Mar 20, 2013 12:52 am
Dannyg420 View the latest post
There are no new unread posts for this topic. Radiators......96 Bonneville.
Speedster400
Mon May 25, 2015 12:42 pm
Jrs3800 View the latest post
cron
