It is currently Sat Mar 06, 2021 6:33 am
 Post subject: ECM-PCM question
PostPosted: Sun Nov 01, 2020 12:56 pm
Year and Trim: 2003 Bonneville SSEi.
Where/who could i send it to have it checked to be sure it's functioning within specs? I ask this because every time i changed the plugs, they have a pinkish-brown tint on the insulator. Indicating a lean condition from what i have read.
Any help and advice is appreciated.
 Post subject: Re: ECM-PCM question
PostPosted: Sun Nov 01, 2020 2:16 pm
How does the car feel? Does it drive normally and feel like it has okay power? No CEL lights or codes?
"Penelope" - 2003 SLE - 218k Miles
"Sydney" - 2000 Honda S2000 - 81k miles
PostPosted: Sun Nov 01, 2020 4:54 pm
You would want to get a scan tool that's capable of looking at fuel trims to see if it's pulling or adding fuel.
PostPosted: Sun Nov 01, 2020 11:22 pm
I have gotten only one CEL code P0420- catalytic converter operating below efficiency.
Short of that, it runs sound.
Checked trim on upstream sensor....... Has the ....|''''|.... Pattern and is within voltage specs. The downstream sensor......well that's questionable. It would come on after bout a thousand or more miles after install. Then again i have a heavy foot. I hear no pinging though.... Except when i have a mysterious shutdown : will post in another thread.
PostPosted: Mon Nov 02, 2020 1:21 am
What are your LTFTs at idle and constant speed cruise?
PostPosted: Mon Nov 02, 2020 10:45 pm
:dontknow: don't have access to car or scan tool to check the numbers. What would be nominal readings?
PostPosted: Tue Nov 03, 2020 1:34 am
As close to 100% as possible. It's basically the long term fuel adjustment memory. Greater that 100 is adding fuel and less than is taking fuel out.
There are no new unread posts for this topic. Question via PM
willwren
Fri Apr 17, 2009 6:24 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. 2nd question
dcbambi2011
14
1470
Tue Jun 08, 2010 5:00 pm
There are no new unread posts for this topic. FWI question for 03 SE.
Turbo30
Mon May 16, 2011 10:13 am
willwren View the latest post
There are no new unread posts for this topic. MPG Question
K-OtiK
19
1803
Thu Nov 20, 2008 1:05 am
K-OtiK View the latest post
There are no new unread posts for this topic. yet another question
Sadden
15
1648
Sun Apr 26, 2009 10:30 am
Sadden View the latest post
